Hey Sheckster,
I think it is time to call the dealer.
If your head lights are on parkers or above and you pull the light switch out one notch, your fog lights should illuminate, along with the green indicator on the dash.
Any deviation from this would suggest a fault.
I would check to see if the lights are working first and not just a problem with with the indicator. They don't make much difference, so check first.
Grant.
					 , anyway, to cut long story short, my fog lamps seems to be broken (no green light on dash) when I pull the swith to correct position (2), the rear fog lights works though (3). Any ideas?, not really crash hot on bringing it to the dealer just for fog lights, but will ofcourse do if it's really busted.
				 ,. anyway, off to check the fuse box now.
