Results 1 to 8 of 8
Thread: Driving Light wiring on D2
    Mar 2009
    Ipswich Qld
    G'day all, I'm looking at fitting IPF driving lights to my D2 td5. I have heard that using a generic wiring loom and relay (instead of a gen LR kit) can upset the BCU and cause problems. Can anyone confirm or advise what they are using? Cheers, Newdog.
    Manly QLD
    Quote Originally Posted by Newdog View Post
    You've been fed rubbish – you can just use a relay, fused +ve feed from battery & switch wire from the rear of the headlight.
    Skellz Guest
    xgt 240 lighytforce
    I wired up my own lights using the lightforce wiring harness and have had no problems
    I thing you have been feed some bull
    Oct 2003
    Montrose, Vic.
    As said.. you have been fed total BS.
    Do yourself a favor though.... if thinking of a generic harness... take a close look at cable sizes - particularly between the battery and relay then relay and lights - decent cable can make a huge difference.
    The standard IPF loom is total rubbish IHMO.
    Mark
    Mark
    2003 D2a TD5...gone...
    2000 D2 V8...gone...
    https://bymark.photography
    Dec 2008
    Beechboro Perth
    I am running the IPF harness with no problems
    Melbourne, Australia
    Smile
    I've used IPFs for long time on my DII but I found that they didn't like to be submerged into dirty water - eventually the reflectors got very "aged"!
    I run Cibie lights now, but they aren't any more water proof than the IPFs, but I don't have to worry about bog holes anymore due to this drought!
    But the point that I'm making is that I have been using the IPF supplied wiring loom and switch and even when I swapped out the lights themselves, I kept the loom.
    Works just fine.
    If you want to use the genuine LR loom, I know that this is a whole complete kit and requires the Testbook to enable the function. I was given a genuine LR driving light kit but didn't bother to install it because it seems far too complex and the IPF solution was already proven across two Simpson Desert crossings.
    Oct 2003
    Montrose, Vic.
    Quote Originally Posted by Disco W.A View Post
    Replace the cable with decent sized cable and a decent relay and you will get significantly more light from the same driving lights.
    Mark
    Mark
    Kippa Ring
    Quote Originally Posted by Bytemrk View Post
    Mark
    You can get decent results even from el cheapo Narva spotties by doing this
    Series 2 LWB - Gone
    Series 3 LWB - Gone
    Series 1 LWB - Gone
    81 RR 2 door - Gone
    95 Disco v8 - The Next Victim
