Results 1 to 10 of 17
Thread: Computer Glitch?
    Palmerston NT
    Computer Glitch?
    Well on the way home yesterday from work and I notice the aircon isn't running... I look at the dash and it says "drivers door open" so I open and close it whilst travelling and then the aircon etc comes back on. Drive on for another 100 metres or so and then the aircon goes off again.
    So I pull over and turn it off thinking that maybe its a computer glitch or something and maybe restarting will fix it - except it doesn't start!
    So I'm stuck on the side of the road. After trying many times to start it and getting errors on the dash about either the emergency park brake or the HDC system unavailable I ring roadside assistance and they send someone out to get me.
    My wife gets there 15 minutes later before the roadside assistance gets there and I go to try and start it to show her what is wrong and it just starts like there was never any problem!
    Any ideas on what it might have been? Should I take it into Darwin Mitsubishi (the local LR mob) to check it? Was it because I waited longer to try and restart it the last time that the computer reset or something?
    Went for a few drives last night and to work this morning and no probs at all...
    Douglas Park, NSW
    D3s never do this so it must have just been a bad dream .
    Take it to the dealer, get them to check the faults logged & maybe check the transfer case ECU behind the battery. They are prone to getting moisture in the connection & causing problems like you've described.
    Palmerston NT
    Just happened again when I was driving out the carpark for lunch.. so I went straight to the dealer... least they saw it in action...
    Left it with them.. hopefully they sort it soon...
    Palmerston NT
    They got it back to me in time for knock off time... they reckon it was the immobiliser.... needed a software update... hopefully they're right...
    They uploaded heaps of updates though.. showed me a list of 3 pages - they reckon they updated all the system so hopefully thats a good thing...
    Palmerston NT
    Still the same problem!
    Took it for a drive today on a gravel.. and I think the problem remains - its just a little bit different now maybe due to the software updates?
    Basically driving along and the aircon will go off.. and then on again. It seemed often to correspond when I hit a bump. Also the door locks would make a noise, and the external temperature display on the dash would go blank...
    So it sounds like a lose connection somewhere? When I got back on the bitumen everything stayed fine...
    I'm assuming that I'm just getting systems cutting in and out with a lose connection but not getting system errors now because software updates have made it more robust and not to chuck a wobbly if whatever component it is is turned off and on?
    I did tell them to check the transfer case ECU as suggested below but they reckon it wasn't that... not sure how well they checked it though... i got the impression that they decided it wasn't as there was nothing logged in the computer for it...
    300+ Guest
    Dunno what the problem is, but there is a mini reset performed when you turn the engine off then back on.
    Apparently there is a major reset performed if you leave it off for several minutes so that the handbrake light goes off (this remains on with the keys out for a while).
    Hence when you waited for your wife the fault cleared as a full start up check was performed.
    Cheers, Steve
    mike 90 RR Guest
    Quote Originally Posted by 300+ View Post
    Cheers, Steve
    .... Top tip there, Steve
    Palmerston NT
    Update
    Darwin Mitsubishi have had it for a few days and they reckon its a "instrument cluster" whatever that is - they are ordering a new one today so it might be a few more days
    Hopefully that solves it...
    Avoca Beach
    In a 38A there are microswitches in the door locks to tell the computer whether the door is closed. It was /is a reasonably common fault that the switch would fail and the suspension not rise. I had it happen to me when I drove a friend's 38A.
    I would be pretty confident that the D3 will also have a microswitch and this may be faulty.
    Regards Philip A
    Sydney, NSW (nr Epping)
    The "instrument cluster" contains your speedo, tacho etc. It's not a common fault, but not unheard of. I suspect that it is more the hidden stuff behind the instruments that is at fault.
    Best Wishes,
    Peter
