Results 1 to 10 of 22
Thread: Where do I get parts
    Nov 2008
    Greenwood WA
    Hey guys I have just inherited an X army recon Series II from my father and his brother and I am loving it. With the top off the girls in biknins just want to get in.
    So far I have had the non genuine stromberg carby recond, have had to replace the valve springs, replaced the radiator, put new door seals on, replaced the hose that goes to the oil gauge, replaced a wire in the dizzy, added driving lights so now i need an alternator, lol.
    I have replaced the tarp roof and replaced the exhaust gasket. Replaced the headlights as well but I love it to death and my mates all want one even though i get a headache whenever I drive it
    What is still left is to replace is
    • the bushes front and back that the springs hinge on, I heard they are a pain
    • The oil/temp gauge needs replacing
    • the tie rod ends for the steering need replacing
    • I want to fit free wheeling hubs as well.
    So my question is, where can I get the bulleted items please, will any auto shop sell the bushes/tie rod ends, will i need a specialist shop for the gauge?
    Any comments are welcome, I want to get it going as well as I can, I have already had it on the Gnagarra powerlines track and I want to take it on the Mundaring/York track as well, Oh I'm in WA guys.
    Thanks,
    Mat
    d@rk51d3 Guest
    Welcome aboard, and congratulations.
    Most parts come up fairly regularly on E-bay, except the dual gauge. You should be able to get it restored though, there are a few guys around that do that sort of thing.
    Your local auto-pro, sprint, etc. should be able to sorce the tie rod ends fairly easily, although E-bay has them alot of the time.
    Have fun.
    Eltham, Melbourne
    G'day mate, my series 2 project is now almost finished! I tried replacing the leaf spring bushes but ended up buying new springs
    Such a pain! I found ebay was pretty good but i got almost all of my parts
    from a place here in victoria Four Wheel Drives - Land Rovers New and Used Spare Parts
    They are not the closest to you i know but they have a parts catalogue to die for.
    NSW, Australia
    If you are going to buy stuff from the eastern states, you would be well advised to use either Land Vehicle Spares or All FourX4 in NSW.
    [B][I]Andrew[/I][/B]
    [COLOR="YellowGreen"][U]1958 Series II SWB - "Gus"[/U][/COLOR]
    [COLOR="DarkGreen"][U]1965 Series IIA Ambulance 113-896 - "Ambrose"[/U][/COLOR]
    [COLOR="#DAA520"][U]1981 Mercedes 300D[/U][/COLOR]
    [U]1995 Defender 110[/U]
    [SIGPIC][/SIGPIC]
    JDNSW's Avatar
    JDNSW is online now RoverLord Silver Subscriber
    I agree with Shonky - I buy parts on occasion from Four Wheel Drives in Melbourne - they have a good catalogue, and excellent delivery. And their prices are cheap. But this is the problem. Many of their parts are the cheapest available, and quality to match, which is fine if that is what you are after!
    But if you want to know you are getting quality parts try one of the others.
    Jun 2003
    Launceston, Tasmania
    Welcome to AULRO, any chance you can tell us the chassis number of your command recon for REMLR ??
    1994 Discovery TDi
    2004 Discovery 2 TD5
    2010 Discovery 4 TDV6
    East-South-East Girt-By-Sea
    1.20 MB
    Quote Originally Posted by matpoli View Post
    Hey guys I have just inherited an X army recon Series II from my father and his brother and I am loving it. ...
    ... What is still left is to replace is
    1. the bushes front and back that the springs hinge on, I heard they are a pain
    2. The oil/temp gauge needs replacing
    3. the tie rod ends for the steering need replacing
    4. I want to fit free wheeling hubs as well.
    Thanks,
    Mat
    Mat
    Congrats on the acquisition!
    In regards to your list. I use All 4 X four in Kotara NSW or Land Vehicle Spares and avoid the mob in Blackburn South but you are in WA so there may be someone closer to you ask Chazza or someone else locally.
    1/ The chassis bushes you may have to burn out the rubber with a propane torch then cut the shell out with a hack saw. Make sure you grease the pin well when you re-fit.
    2/ They are still available from a lot of places. Try John Craddocks or Dunsfold's in the UK.
    3/ Make sure that the tie rod ends you get have the un-threaded shoulder (see below).
    Many parts suppliers will tell you that the ones with the thread all the way along are suitable for all Series Land Rovers from 1948 through 1982. This is incorrect and fitting the completely threaded ones to a Series 1 or series 2/2a is both unsafe and illegal. You can get the shouldered ones from All 4 X Four upon request.
    4/ I would/will not fit freewheeling hubs. There are as many disadvantages as there are advantages. Do an AuLRO search on freewheeling hubs and make a decision.
    Diana
    JDNSW's Avatar
    Diana
    I agree entirely with Diana on this but would caution that you must also check the tube they are screwing into to make sure that it is the correct one for the tierod end. Using one with the clamped bit threaded on one bit and smooth on the other (either way) is unsafe and has resulted in fatal accidents.
    I would probably not bother with freewheeling hubs - despite the fact I have them on my 2a; they are rarely disengaged. Driving for extended periods with free wheeling hubs disengaged will lead to a variety of problems with the swivels and possibly the diff and drive shaft. I have been unable to measure any difference to fuel consumption with them, and there is no subjective change in performance or noise/vibration. (I paid $15 for mine, complete with a chassis and bulkhead plus front and rear axles/ springs, so I have lost little!)
    1.20 MB
    Yes that's correct John, as you know the shouldered tie rod ends and steering links were the original equipment on the Series 2, so if they are not present (like the strongberg carby) then the vehicle is a hybrid and care always has to be taken when replacing bits.
    The F/W hub issue is the subject of a number of threads, I personally do not use them and in fact remove F/W hubs from vehicles upon purchase. So the matter is very much a personal preference but the choice should be made after reading ALL sides of the issue, not just because someone's mate suggests them or not.
    Diana
    Narre Warren South
    Matpoli,
    Re: spring bushes
    You will need some way of drawing the old bushes out and the new bushes in. I cut the rubber using a hacksaw and then cut through the outer part of the bush to allow it to be drawn out with the tool shown in the attached link.
    Getting the Series 1 Ready for Cooma
    Bushes were from Four Wheel Drives, reasonably priced from memory. PM your email address and I can send a .pdf of their catalogue.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
