Thread: burning to much fuel
    normz81 Guest
    Unhappy burning to much fuel
    gday i am a proud owner of a range rover 93 vouge sle and i am looking for a way to lower my fuel consumption?? a mate of mine suggested that i should should put extractors with an after market exhaust on it with a chip also he rekons it should bring my fuel down to about 13lt per 100km rather than 18lt per 100km any sugestions???? also having problem with automatic locking system key?? any thoughts??
    Nowra, NSW
    18L/100km sounds pretty normal!
    Goolwa SA - but top ender forever
    I have to agree with Lucy 18/100 sounds about right - to fairly good if it is in city traffic. yes extractors will help (and it makes it sound even better) I cant quanitfy exactly how much it helped but the snorkle I added to mine (disco 94) has helped, probably because it is getting cooler outside air. I haven't chipped mine but from what I have read and heard will help as well.
    Normal things like ensure you have good leads and plugs and solid earth so you get a fat spark, clean air filter and oil as well.
    Finally the hardest (for me ) is to drive with a gentle right foot, I tend to have a heavy right foot and I get crap economy because of it, but I have fun so it's a trade off.
    Blythe
    Back down the hill.
    Driving style is the greatest influence on economy. I get 500k for under 90L, round town.
    Dec 2008
    Victoria
    Check your vacuum advance diaphragm. This is probably perished by now due to age and will cause excesive fuel consumption.
    Apr 2007
    NW Tassie
    300tdi
    blaze
    Apr 2007
    Prospect SA
    18L is good.
    Put it on gas, if you are in SA go see a guy called Jilden Reichart in Crafers West.
    He is a whizz on Landy conversions, did 3 of mine.
    After rebate and using a tested tank, cost me $150 dollars to fit a top system. Never back fired nothing and will cut your your fuel bill in half.
    He will change leads and plugs to better suit gas, advance timing and does generally a fantastic job for little money.
    Say Frank send you.
    I must warn though, he is a bit eccentric.
