Results 1 to 8 of 8
Thread: Disco 300tdi - indicator double speed
    Gents,
    Got a friend with a 300tdi discovery and the left hand front indicator is running at double the speed of the other three.
    Is this the flicker unit that is stuffed or the relay or am I on the wrong track?
    any ideas on how we can fix this?
    The entertainer
    www.nata.net.au
    Douglas Park, NSW
    Do all 3 side indicators flash? Double speed is normally a sign a globe is out.
    Or someone has fitted a 5w globe to the front/rear instead of a 21w.
    Adelaide - Torrens Park
    It can't possibly, if the other three you are talking about are LHR, RHF and RHR. There is only one flasher can, so a front indicator can't flash at a different rate to a rear one.
    It is more likely that all the bulbs are working on one side and there is a blown bulb on the other.
    The change in flash rate is designed in (and required by ADRs) to alert the driver that there is a fault.
    thanks
    Will let him know and let you know if it's the issue...!
    thanks for the help!
    Bracken Ridge, Qld
    Hmmm the same thing happened in my 'fender the other day - I'd better have a lokk !
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    Adelaide, SA
    My money is on a blown globe
    Melbourne, outer South East
    yep blown globe or dirty contacts.
    mine use to do it now and then i'd give the front indicator a thump and it came right - I was meaning to fix it then sold the car
    South East Tasmania
    In my Defe happens some times so have to be a bad contact some were.
