Results 1 to 8 of 8
Thread: rave 1970 - 1985
    richard4u2 Guest
    rave 1970 - 1985
    is any one running this cd on thier computer if so what o/s are you using as i am having no luck running it with vista as adobe reader 6 that was on the cd is not compatible with vista, adobe could only give me 8 or 9 as been compatible
    thanks
    Jan 2009
    Gold Coast home of Maxi Drive
    I run Acrobat 9.0 with Vista & Rave works fine.
    If the CD covers 1970-1985, it isn't a RAVE disc.
    richard4u2 Guest
    more info its a RRMAN 70 -85, i have loaded the reader 6 that was on the cd but when i click on one of the manuals i get this message
    " sorry, but the application could not be found on your system "
    any clues as to what is going on
    Jun 2003
    Launceston, Tasmania
    you are getting acrobat 6 conflicting with a newer version of acrobat on your machine I would say
    I'd uninstall acrobat 6 and let the latest version do the job
    Or reinstall the later version that you have (8 or 9). that should also fix it.
    1994 Discovery TDi
    2004 Discovery 2 TD5
    2010 Discovery 4 TDV6
    richard4u2 Guest
    had 9 on , didnt work, deleted that, put 8 on didnt work deleted that, put 6 on didnt work, thats still on as it came with the cd
    Just guessing but I'd try copying the whole disk to a folder on your PC and then run the EXE file in compatability mode (right click\properties\compatability). You might even convince Acrobat 6 to run on Vista? Worth a shot.
    Discocam
    richard4u2 Guest
    it runs alright on another computer which has XP but wont run on mine with vista
