Results 1 to 8 of 8
Thread: my passport essential
    richard4u2 Guest
    i have 250 gig passport (external hard drive) and i have downloaded my files (photo,e-mail etc etc) with the software that came with it but i would now like to down load the whole hard drive as a backup just in case the one in the computer takes a fit but i need a programe, windows has one but it is only for the top 3 vista programes not for the vist home basic or premiun , nortons has one but its $99 . does any one know of a programe that is a lot cheaper
    thanks
    Jul 2009
    Hobart
    Hi,
    you can't download the 'whole hard drive'.
    To be running your original HD you have to have some files open, and these wont back up.
    You can get around this by starting your computer from another drive (eg cd or another hd) but this is getting messy.
    Usually you only backup files you have created, eg email, photos, documents etc and reinstall the programs and operating system if you have a fatal failure.
    You should have all the install disks, (operating system and programs) stored safely for such an event.
    Program and operating system updates that have occurred can be re installed once on line again.
    Another reason for not attempting to back up the whole hd, is that if you want to 'clone' it to another disk, the new disk will need to be identical in every way to the original or it will be faulty.
    It may be difficult to obtain exactly the same disk some years down the track.
    Yes, you could buy two disks with the new computer, and this does open the opportunity to 'mirror' them, but it is all getting very difficult and perhaps over complicated.
    Backing up the created files, and reinstalling programs is the usual way of doing things.
    mikehzz Guest
    Hard Drive Data Recovery Software. Disk Recovery & Data Recovery Tools to Recover Deleted Files - EASEUS Data Recovery has Disk Copy 2.3 for free as well as partition resizing software. Create bootable CD from the iso image, boot and clone then resize the partition. It works using usb drives etc
    Mike
    Melrose SA
    You can take an image of your whole hard drive so yes you can copy your whole hard drive
    Download Clonezilla live cd I use the Ubuntu version it is fantastic and will do what you want.
    I would turn off system restore and then run the backup that way you will minimise the size of the image.
    Read up and understand what you are doing if you overwrite you o/s with your external drive you will not be a happy boy
    Oh sorry in the spirit of Linux its free
    richard4u2 Guest
    thanks guys , i do have all the orignal disks etc , have to give it a lot more thought
    Microsoft should be strung up for doing this to their "valued" users. All versions of their OS should come standard with quality backup software.
     2005 Defender 110 
    Jun 2008
    McMinns Lagoon NT
    Cheers, Dale
    'The D3' - 2006 TDV6 HSE
    Previously Enjoyed:
    2000 D2 Td5 - plus!
    May 2006
    Carlton, Melbourne
    I use Acronis True Image and have found it faultless, it even let's you take a ful image whilst still using your computer.
    I'm using an older version though, I'm sure the newer version is even better.
    Can't recommend it enough.
    Fraser
