Results 1 to 10 of 16
Thread: URGENT NANOCOM HELP
    tyreplus4x4 Guest
    URGENT NANOCOM HELP
    I have just been installing nanocom and trying to work out functions with ignition on the red light in speedo came on the engine light with a stroke through it comes on when i try to start engine there is nothing apart from horn beeping twice and no power, all lights and acc work what have i done.
    unplug nanocom, lock car, wait 5 min...
    come back and unlock.
    See if it starts.. if not, post again!
    tyreplus4x4 Guest
    Quote Originally Posted by Tombie2 View Post
    Hi Mike i did what you said but no luck,the red light in the speedo flashes when door closed and stays on when door open with no ignition on,it also stays on when ignition on.
    Hope you can help Thanks George
    Check the Disco's battery charge. It's probably dropped below 11.5V. If so charge it up and retry.
    tyreplus4x4 Guest
    Sorry mate it is a Defender and both batteries are fully charged.
    Cheers George
    Must look at the avatar picture next time
    Have you got the EKA for the Defender? If so try using that.
    tyreplus4x4 Guest
    No there is no EKA
    Williams West Aust
    I wonder if you accidentley changed the security coding whilst exploring.
    Have you used a laptop with Nanocom??? Just makes it a bit easier to use.
    Go into the TD5 motor section,click learn security code(or similar,cant exactly remember how its worded) it will re-sync the imobiliser in the ECU.
    If this dont work,post again.
    GOODLUCK
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    tyreplus4x4 Guest
    GOODLUCK
    Andrew
    Hi Andrew i did what you said but still the same the nanocom does say the imobiliser is on.
    Thanks George
    May 2009
    Hi
    just a quick question but did you by any reason change the EKA code
    while playing with the Nanocom?
    If so have you tried to "RE-sync" ie by inserting the code with the Keys
    in the drivers door? Follow the instructions CAREFULLY from the owners manual.
    Good Look
    Vince
