Results 1 to 10 of 17
Thread: So there's actually nothing wrong with this?
    This is the left hand rear lower shock mount on the Puma. The right is identically put together. These are as delivered and have not been touched.
    Can you spot anything amiss?
    Last edited by dmdigital; 8th November 2009 at 07:52 PM. Reason: Changed title to reflect information in thread
    Adelaide - Torrens Park
    Looks OK at a glance. What is the issue?
    Isn't the washer upside down? Maybe different on a Puma looking at that tubular bit on the mount.
    Spot on Ron That tubular bit is the lower rubber.
    I've crawled all over this car in the last 12 months and last weekend when I was changing the Diff Oil after the big trip I just happened to notice that both rear shocks have the outer washers on upside down
    Of course maybe this one's built for the Northern hemisphere so then they'd be right way up
    miky Guest
    So now we wait while everyone rushes out to have a look at theirs
    Quote Originally Posted by miky View Post
    The thought never occurred to me
    But it will be interesting to see if anyone else's is like this.
    May 2003
    On The Road
    Kingston, Tassie, OZ.
    They're supposed to be that way Derek, the rubber bushes are conical too, and if fitted the wrong way up won't work at all
    The same is true with D1 from 1994 update.
    When I fit the bilstein or DeCarbon shocks, I remove the steel 'tubes' and revert back to 'normal' shock rubber and washer orientation.
    JC
    JC
    Hence my post saying that they looked alright to me .
    Brisbane,some of the time.
    Anything else we need to look at while we are there?
    It'll save two trips
    Ohh,the front ones are around the other way
