Use a screwdriver(s) to prise the jet part of the new whasher nozzle from the stalk. Do the same with the nozzle fitted to the vehicle. Then just push the new nozzle on the remaining part. I did this when I had to replace the washer nozzle on my 90. Works a treat and no messing with trying to get to the nut.
IIRC I used two screwdiers carefully to prise the nozzle part from the stalk part.
HTH
Ivan
 , CV also chewed out. So got all 4 hubs converted to oil lubed and got Hytuff rear axles and flanges. Got EGR bypass kit on the way as well.
