Results 1 to 10 of 14
Thread: calculating front to rear brake %'s
    hey all,
    how do I figure out the front and rear brake percentages for a 98 Def 110. If the total braking area is 100% what percentage is front and rear.
    cheers,
    Serg
    the easiest way is to put it on a dyno roller and test them.
    you can calculate it roughly by working out the piston surface area of the front and rear calipers and then expressing that as a percentage.
    if you have a brake pressure modulator of any kind you have to work it out as the overall force that the calipers can exert which is the calipers total piston area multiplied by the fluid pressure. do that for front and rear and then express them as a percentage.
    from memory the split is 60/40
    Somewhere else, QLD
    This is an expansion of Mr BK's dyno suggestion
    Safe-T-Stop - Brake, Steering and Suspension Safety Test
    One of their reports came with the RR I picked up in Vic. Strange as it seems it was 70/30 f/r, but it was a 20 yo vehicle after all. It even measured variations L/R on each axle. ( 13% FNS, 27% RNS)
    I may well be wrong but werent the orignal RR twin pot twin piston fronts with single pot rears? This would make some sense to the large % difference
    Serg
    Regarding calculating it, would pad size come into play?
    what are the piston sizes and number of for front and rear of a 1998 Def 110 trayback
    Serg
    yep, thats why I said roughly calculate.
    cheers,
    do you know the front and rear piston sizes?
    not off the top of my head no.
    out of curiosity why do you want to know the brake bias?
    (send me a PM tonight And I'll dig the raves/rps/emei/partsmanuas and see if I can find enough to give you a close enough to right answer)
    so i can calculate the amount of anti-dive on my truck and play around with some front end designs.
    why is it that this worries me a little?
    Ifff your going to be doing what I think your going to be doing might I suggest that you get an early rangie setup for the brakes and on the secondary plug in a proportioning valve?
