Results 1 to 10 of 16
Thread: What temp to cut in thermos?
    Range Blitzer Guest
    I have installed thermos on my 82' Rangie and want to instal a temp cut in switch threaded into the manifold, but i'm not sure what temp switch to get. I know the thermostate is rated at 78 - 83 degrees, so should you have the thermos cut in after the the thermostate opens, say 85 -90 degrees or the same? Not even sure yet what if any variety there is in these switches. Any opinions welcomed!
    Robert.
    Avoca Beach
    I would have it about 5C over thermostat fully open.
    Regards Philip A
    Hi,
    Plenty of switch info here:
    Outer Limits 4x4 Board :: View topic - Thermo fan info
    You can get an alloy tube with one or two threaded holes for senders that you fit as part of the top radiator hose. (i.e. cut a section out of the hose and fit the tube with hose clamps)
    cheers, DL
    Mar 2007
    Perth WA
    My main fan cuts in at 93 and off at 91, the secondary cuts in at 95 and out at 91. This seems to stop too much heat getting into the rad when towing up hill. I occasionally see 108 to 110 but it drops down quick once the loads off. Coasting down hill with this setup wuill often see the coolant temp drop down below thermostat opening temp (sometimes down to 83deg) so the fans allow plenty of flow when off. Im using ea falcon fans
    Oct 2007
    Temp help
    I don't want to take your thread over but I have a question the same.
    I have a thermo fan fitted to the defender only 14" not big enough (getting 16"). My question is, Is the ajustable switch that you get with the Davis C fan any good or am I better off getting a fixed temp sender for the fan. And what temp?
    Mandurah. W.A.
    No problems with the DC adjustable thermostat so far, been fitted for approx. 18 months.
    Maggsie
    04 V8 Disco
    85 V8 County
    On at 90, off at 85.
    just make sure as said before the thermostat opening temp is less than the fan cut off by 3-5 degrees.
    Andrew
    Mar 2007
    Perth WA
    Are you running an 82deg thermostat Andrew?
    Quote Originally Posted by Lucus View Post
    Certainly am!
    I changed the switch on my thermo housing to the above, removed the original condenser fans and wired the thermos up to that.
    They come on at 90 via the switch and automatically via the A/C.
    Andrew
    I want to mount some twin thermos on the front of my radiator to assist the mechanical fan, whilst on the beach or low range stuff. Is it a case of just getting some ford type thermo's and reversing the wiring so they blow instead of suck or do I need to dismantle and reverse the props?
