Thread: TD5 Not Starting
    Vazza Guest
    TD5 Not Starting
    Hi All,
    Was up at the Sunny coast (Marcus Beach) for the last few days and strangely had a problem starting my 2004 Td5 D2a. Now I have only just recently bought the car and have never had an issue till we got up the coast and funnily enough, now that were back home the problem has disappeared
    I have read the Amcal Chem. security systems and RF interference posts, but the cars security functioned perfectly, locking/unlock via remote all worked. Then I put the key in, turn, wait for glow light, turn key fully and nothing bar a slight clicking noise (seemed to come from engine bay).
    So I turn the key all the way off, try again and she fires up as normal. Sometimes it required 2 - 3 goes before it started.
    But as I said now im home it starts first time every time.....Any ideas what it could have been?
    Ps I was very low on diesel when we arrived, dont know if that should matter
    Douglas Park, NSW
    Auto? If so, did you try it in Nuetral?
    Sometimes a coin can get under the cover & stop the lever from going all the way into Park.
    Vazza Guest
    Thanks for the reply.......
    Yes, its an auto. No I didn't try it in neutral, one of the times it happened I did cycle through the gears, then back into park and I don't think it started until I turned the key all the way off and tried again
    Bacchus Marsh Vic.
    Possibly in the starter motor contacts.
    http://www.aulro.com/afvb/projects-t...hlight=starter
    Mine did the same about once a month but never concerned me till I got it wet(Then it just "clunked",Engaged to starter ring but no turning).
    Cheers, Kyle
    The Good Oil.
    When did you last visit?
    Dec 2009
    Carnarvon WA
    TD5 solenoid kit
    Same prob with my 2000 td5 auto @ 194,000K.
    It will definitely "start" happening more often, and at awkward times, and take more "clicks" to engage the starter motor.
    I bought my starter solenoid kit from Jagspares & British 4WD (Ebay) for $82.70 total (inc postage & GST).
    -Wasa
