(1 )   I am going to change the fuel filter and can some one please clarify how to proceed with this my Defender does not have a water temperature on the bottom of the fuel filter ( or am i looking at the right place for it on back right hand side where the filter is .) and do i just change it over and start the Defender or do i have to fuel purging procedure.
No Defender doesn't have the water connector, last of the D2's didn't either.  Yes, change it over and then start the defender.  If you need to "prime" it, this is in the owner's handbook.
(2)
Going to do a oil and filter change what oils are best for these Defenders.
Castrol Magnatec is fine.  Though lots of others will have lots of different opinions.
(3)
Going to change Diffs oils and gearbox oils and transfer oils if you could recommend what is the best.
Castrol EPX85W-90 for the Diffs and transfer case.  Don't know about the gearbox on the Td5 Defender
If you do buy Castrol oils, price them at a distributor and not Supercheap/Autobarn/etc or similar as you will find they are a lot cheaper than the usual outlets.
