Results 1 to 10 of 24
Thread: Turbo Encabulator for Puma Defender?
    Maleny, Queensland
    I just MUST have one of these for the Defender. I believe they make models you can retro-fit to earlier Tdi engines, but not Td5s unfortunately as they use the slightly different Turbo Enscrambulator which doesn't rely on a constant flux modial input, but a constantly variable flux modial input...
    [ame="http://www.youtube.com/watch?v=MXW0bx_Ooq4&feature=player_embedded"]YouTube- Chrysler Turbo Encabulator[/ame]
    Safety Bay
    I've worked with blokes like that,if you can't dazzle them with brilliance,baffle them with bulls**t. Pat
    May 2008
    Albury Wodonga
    Ahh yes, the turbo encabulator! I really do love the line "If the result are above 10RG, replace the unit, if below 10RG, you will be directed to perform a series of tests, which will raise the billable service hours for the service department, but will perform no other useful function."
    An oldie but a goodie!
    Back down the hill.
    Quote Originally Posted by solmanic View Post
    I take it you are aware that to fit this unit to any (non-TD5) Land Rover product the wheels must be fitted inside out, in order that the reversal of transmissional rotation is rectified.
    and you should see the power increase when you add a hiclone to the exhaust and plug in a fuel polarizer
    May 2008
    Albury Wodonga
    Don't forget the dozen rare earth magnets in the fuel tank, otherwise not all components will synchronise to give maximal outputs!
    I thought you had to put them on the oil filter canister to "magnetically align" the oil. Once aligned the oil that leaked out past the seals then carried on the process on the rest of the vehicle taking advantage of the residual cohesive alignment fields in the oil...
    Maleny, Queensland
    I'm just hoping that such a device will correct the rotary, multi-phase castellation which the vehicle has had since the last cylinder air-passage re-alignment. It's getting quite annoying and the dealer (unsurprisingly) doesn't seem to know anything about ow to fix it.
    Maleny, Queensland
    I heard that you can avoid having to invert the wheels by paying another $80 for a RHD encapsulator... or simply swap the hubs from left to right.
    Maleny, Queensland
    Quote Originally Posted by seano87 View Post
    Rubbish! I was told the rare earth magnets had to fix to the topside of the cylinder head in a smiley-face pattern. Putting them in the fuel tank is a myth! Unless you are confusing them with quadra-resistive micro-pellets which work a treat in the fuel tank!
