Results 1 to 10 of 16
Thread: Defender 130 water tank.
    Jul 2008
    I have a deefer 130 with an ally tray. There is about 160mm high by 1 meter wide space above the tray supports. I was thinking a tank would fit perfectly in there. Has anyone fabricated a water tank for this area. Any sugesstions or help would be appreciated. Thanks.
    Torres Straits
    Also have a 130 with ally tray.
    I have an Al fuel tank in that space you are talking about. It holds 75L.
    I put a near on 45L water tank under the passenger sill.
    Fuel tank was made by a pro out of 3mm plate. Use a fuel solenoid to switch between the two tanks.
    I built up the water tank out of some 3mm chequer Al... using compressed air to pump the water out to a tap between cab and tray.
    S
    South East Tasmania
    It would be more appropriated to move this thread to the Defe/Puma forum so we can read the inputs in the future
    Nov 2007
    Wodonga Vic.
    Quote Originally Posted by roverrescue View Post
    S
    I plan to fabricate a under tray tank for my new 130 (when it finally arrives here in OZ) please post some pic's of your version. please include the under sill tanks.
    Allen
    Nov 2006
    narellan, sydney
    if its a 130 dual cab, a caravan plastic 55L water tank fits nicely under the rear seat. you just need to cut the hole larger.
    Andy
    gold coast
    is your gravity fed? or electric pump? i tried to eurathane the joins and seal the lid with a tap out the side but it leaked and i gave it up as a bad joke, i like the caravan option as its safe and keeps the water cool in summer. Have you got any pics to show?
    Nov 2006
    narellan, sydney
    It was gravity fed, with an inlet and outlet on the triangle piece behind the back door. I have some pics, but i have to find them first, there may be some in my sisters 130 buildup thread in projects section. I had to cut the hole all the way from the back where it bolts on, to the front, just behind the seat angle brackets. The plastic molded tank was only $100 or so, and the fittings and hoses were about $20. The water still heated up when it got hot though not as much as if it was under the car.
    Andy
    ashman Guest
    I have a long range fuel tank under my steel tray it feeds into my standed tank, I'm going to put a water tank under to back seat for drinking water and at the moment I'm building a strong frame for the tray it won't be as high as the roof of the cab but I will be able to mount 2 spare wheels a solar panel and thinking of putting a 100 ltr black bladder water tank so when its full it will give all the warm water for showers and washing etc, it will only be full when camping for a few days and when empty it don't take up much room, I'm building the frame so it can be easly taken off when not in use...
    Ashley
    Jul 2009
    NSW
    Has anyone tried installing a bladder or something under the drivers seat?
    You need to move the ecu and fuses to a new box under the cubby box, all the wires reach fine.
    If anyone has, I would like to know a bit more about this
    gold coast
    I met a guy on the coast with a 130 and tray on the back, he had gotten a holden fuel tank and installed it as a reserve under his tray and used compressed air to pump up the tank to force it into the main tank, i thought it was a good idea.
    Also had a caravan 65 litre under there for trips.
