Results 1 to 10 of 14
Thread: Help! Nanocom has bombed out.
    Dec 2008
    Riverton W.A.
    After much debating just tried to download the 2.05 up grade. Tried 5 times and it doesn't want to know me.
    Gave up and put the Nanocom back in the vehicle. Turned the key on, then the Nanocom to check that everything was ok only to find that the comment "function locked please insert relative unlock code".
    I found that the I.D. code has dissapeared together with Nos 1 and 2 set up codes.
    I have reprogramed the 1 and 2 setup codes but, how in the heck do you re-enter the I.D. code???
    Can someone help Please, even pretty please.
    Tony
    23skidoo Guest
    Nanocom ID
    The Nanocom ID is unique to the unit and AFAIK you cant enter or amend it . It would have been provided with the unit and its the one you used to register the device to get the unlock codes. You should be able however to view it . from the SETUP options if you can get there .. to see if its the same as the one you think it is from your registration. I would be inclined to suspect your firmware update probably needs to complete as its in an unstable state , or else and as you are having trouble with the update possible easier , you need to re-apply the firmware that you previously had and was known to work to return it to a working state.
    Dec 2008
    Riverton W.A.
    Quote Originally Posted by 23skidoo View Post
    Thanks for that, unfortunately it still doesnt let me in. Must be something to do with the ID code. Looks like I will be contacting Italy.
    Thanks anyway.
    Tony
    Has happened to a few of us...
    Mine was re-flashed with a program from Italy, but still wont work...
    Its on its way back for repair
    Ellendale Tasmania.
    Landyandy fixed ours, give him a PM.
    Baz.
    Cheers Baz.
    2007 BMW R1200GS
    Williams West Aust
    Hi Grumpy
    The 3 Ive fixed were all boot failures.
    Ive got Mattias programmer.
    Contact Mattia first and see if re-programing the boot sector is the issue.If so MORE than happy to do it for you free of charge.You can either post it or come down for a drive(1 1/4hrs from Armadale)
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Dec 2008
    Riverton W.A.
    Hi Grumpy
    Andrew
    Thanks Andrew,
    Sorry for the delay in replying, have been down at Mandurah with 4 grandkids and only got back today.
    Williams is just down the road!!
    Before I went, I contacted Mattia and have just opened his reply this afternoon. Have now reset every thing including the nanocom's I.D. Could not do this on an external power supply, only through the OBD cable in the vehicle and my wireless laptop??? My problem now is that the Nanocom will not converse with the ECU. Have checked everything out and I am buggered if I can work out why. Might have to pay you a visit and see if you can sort this thing out. Will PM you for details if I need your assistance.
    Tony
    Quote Originally Posted by Grumpy View Post
    Thanks Andrew,
    Tony
    Mines done exactly the same.....
    Williams West Aust
    Guys
    Mine does that from time to time.
    If its the same problem as mine disconnect the yellow obd cable at the Nannocom end and re-fit whilst nanocom is running.Seems to work for me.
    Andrew
    Dec 2008
    Riverton W.A.
    Guys
    Andrew
    Thanks Andrew will try tomorrow.
    Have been in touch with Mattie and his comment was that there could have been a glitch in down loading and to try down loading again. If your suggestion doesn't work will retry downloading the upgrade again. If that doesn't work buggered if I know. May be try and download the original program. Had no problems with that.
    Tony
