kmart/supercheap/autopro/autobarn/repco/auto one
they all stock Nulon OAT.
I did a service on the discovery last weekend, with the assistance of a mate who is a mechanic.
We changed the coolant, however being in a bit of a hurry, and given that it was in good cndition, didn't remove the alternator to drain the block.
The part that worries me is that we used coolent that he had in stock, Tectaloy Extra Cool Red. Although it says "Silicate and Phosphate Free" I don't think its an OAT coolant.
So given there would have been a fair amount of coolent left in the block, and I have possibly mixed two different types of coolant, do I need to flush the entire system and start again? If so where in Melbourne is the best place to get OAT coolant on a weekend?
Thanks in advance
Matt
Last edited by Blknight.aus; 20th February 2010 at 09:04 AM. Reason: forgot repco and auto one
in this situation i found it easier to fill up with water run engine so water mixes with old collant ,turn engine off ,drain radiator and repeat normaly 2 x until you get all water then fill with Nulon oat
cheers Kelvin
I could be wrong but I vaguely recall, from many years ago that tectaloy has a neutraliser that you can add to the last water refill which can eliminate problems caused by mixing different coolants. It might be an idea to check that out given that you probably have a mixture in there now.
Martin
Well I descided to play it safe... drained the coolent, flushed the system and replaced with OAT coolat.
At the end of the day it only cost $50 odd, cheap for piece of mind!
Thanks for the advice
Matt
If its red, then its basically an OAT coolant, green and its Ethylene Glycol.
GM use a specific orange coloured one also.
All coolants now are colourcoded for application.
Andrew
OAT. What is OAT. Why is it better than green coolant. I have been advised that the water pump in my td5 needs replacing. Would like to know more about this coolant issue before the job. Could someone please point me in the right direction for water pump replacement. I can't even find it.
the RAVE cd will explain the pump,,
as for the other,, maybe a quick SEARCH ??
or you could try
The Good Oil
'97 to '07. sold.![]()
No offence but this is a bit misleading, colour coding as explained is not really the full picture.
One such product on the market, Shell (with the well known Shell trademark) Coolguard OAT is red/pink in colour and states on the label:
"Shell Coolguard OAT ready to use is an ethylene glycol coolant/antifreeze specifically formulated with Organic Additive Technology for excellent stability, long service, excellent corrosion protection for all metals, when used correctly. It is nitrite, amine phosphate, borate and silicate free........" It goes on to list that it meets the requirements of international standards and major automobile manufacturers with a number of such standards and car manufacturers etc.
It further states that it is suitable for all automotive applications, including cooling systems incorporating aluminium materials.....also antifreeze, antiboil and antirust.
The product is freely available from K-Mart and other retailers of auto products. (I am not connected with either the product or any company/individual that retails it, purely for information only).
The above is simply for clarification and warning in regard to the colour coding issue stated because it has OAT prominently displayed on the label and is pink/red in colour. It really pays to read the labels of such products before making any decisions.
Again, not looking for any arguments here, but facts are facts. Apologies to mods if mentioning retailers or manufacturers breaches any form protocols.
Mick
