Results 1 to 10 of 12
Thread: 300 tdi front wheel bearing
    Sussex Inlet. N.S.W.
    The bearing lock nut on the front drivers wheel keep backing off despite having fitted a new locking tab washer. So much so that there is noticable play in wheel when rocked. Also there is a very slight vibration caused by wheel movement when braking slowly. How can I keep the bearings nipped up when I can't keep the nut from backing off? Jim
    Jim VK2MAD
    '17 Isuzu D-Max
    300tdi should be - thick washer over bearing, bearing nut, bend over washer, lock washer. Lock washer gets bent over in both directions.
    Td5 has a single nut that has to be done up
    to Oh my God hernia foot pounds.
    Everything is in the correct order, it's just that the nuts work loose somehow. Jim
    Jim VK2MAD
    '17 Isuzu D-Max
    Douglas Park, NSW
    Is the lock washer locating in the stub axle correctly?
    Have the bearings been replaced recently (thinking that the cones weren't fitted fully home)?
    Haven't actually checked the bearings yet. When I nip them up they seem to run freely with no noise, but I suppose it might be a good place to start. Jim
    Jim VK2MAD
    '17 Isuzu D-Max
    Or someone used the lock washer with the tab on it rather than the one with the flat section and it is spinning around thrashing out the stub axle threads?
    Douglas Park, NSW
    Quote Originally Posted by abaddonxi View Post
    That sounds like a man with experience of this .
    Didge Guest
    Yeah, I'll agree with that. There's so much to learn and some people seem to know so much. Hey, I just noticed you guys all joined this site 40!!!!! years ago!!!!!!!!! or is that a typo or are you guys the founding members?? Crikeys, I was only 11 back then
    Quote Originally Posted by pirasea View Post
    .... Hey, I just noticed you guys all joined this site 40!!!!! years ago!!!!!!!!! or is that a typo or are you guys the founding members?? Crikeys, I was only 11 back then
    Our parents signed us up before we were born.
    Vivid imagination and was given some by mistake one time.
