Results 1 to 10 of 23
Thread: Puma warranty issues
    Feb 2009
    Mt Barker, SA
    My 2010 Puma has an ARB OME 50mm suspension kit. Landrover Australia have stated this negates my driveline warranty. I have had the rear diff pinion seal replaced by them once as a 'gesture of goodwill'. It has gone again (10K) as well as the rear transfer case seal which has drenched the handbrake shoes with oil. LRA have refused to fix these as they blame it on the suspension. The transfer seal was the subject of a warranty recall for this very issue that is affecting mine - they still wont do it. I had the vehicle assessed by the RAA techs who have said the suspension is not responsible and LRA should fix it - LRA still refuse. Anyone else out there had their warranty denied for fitting a non standard suspension? Any suggestions or lawyers? Already under warranty I have had the brake vacuum pump, front diff and rear pinion seal replaced and switches on the dash replaced that were faulty. Now I have leaking rear transfer seal and diff pinion and they wont do anything - very frustrating. See the photo of the rear driveshaft uni joint angle taken on level ground - would this cause damage, I think not neither do the RAA techs - what do you think?
    Feb 2009
    Mt Barker, SA
    Sorry heres the photos
    NSW far north coast
    LRA are just trying to get out of it, there is no way a small lift, any lift for that matter will affect the diff pinion seal.
    If you have the RAA onside approach your state Consumer Affairs office, that might make LRA take some action.
    Nov 2007
    Gold coast
    I think this is iffy ground, but LR will always play the card of anyone fitting non, standard parts, will therefore not have related problems covered by there warranty. I am not saying this is fair or not, it just covers them, however, would the same apply if LR fitted you a ARB bar ( to which they do as LR no longer offer one ) and say you have a front suspension issue, and they say they would not fix it under warrenty as the bar may have played a part in this.
    Are the ARB parts, authorised by LR for use?????
    Can you find out if this is a common problem with the puma, and thus prove your upgrade was not at fault
    miky Guest
    I have said this elsewhere:
    When I ordered and paid a deposit for my 110 back in January (delivered in June) I specifically asked about adding stuff and warranty issues.
    ARB bar and Warn winch; OK.
    ARB long range tank; OK
    The other tank that fits behind the right rear wheel where they drill a hole in the existing tank; No
    After market suspension (I didn't specify what); No
    LR heavy duty suspension to counteract bar and winch weight; OK
    I got them to fit the LR snorkel since I was worried about warranty issues if I fitted a non LR one myself. Any problem with the common rail system is a VERY expensive exercise.
    All of that said... these very points have been made many times in this and other forums. This is why I joined this and other forums specifically to learn about possible warranty issues.
    I do feel for those people who, through no real fault of their own, have fallen foul of warranty issues.
    Lets face it, we all (surely) at some time or another have had to take the "experts" word for something that we know nothing about.
    Qld.
    Quote Originally Posted by miky View Post
    I
    Funny - My dealer explicitly told me it WAS OK to fit the Opposite Lock gravity fed fuel tank (this is the one that sits behind the driver's rear wheel).
    2007 Defender 110
    1993 BMW R100LT
    NSW far north coast
    I'd like to see proper legal advise, but IMO if you had uni binding that would be grounds for no warranty but a pinion seal ??
    That's just running away from an obligation and using a poor excuse to do so.
    BTW, did you measure the change in height between the bump stops re the stock and OME springs ?
    I'd bet it's less height difference than when fitting the HD rear setup, ie. the old 330lb/in mains and 140lb/in inners, or whatever variable rate rear spring they now use on the 130 with the secondary inner spring.
    If it measures the same or less I'd be asking for a 'please explain ?'
    scott oz Guest
    For LR to deny any warranty claim they need to prove that the work you did is the likely cause or contributing factor. Generally manufactures do this by simply denying the warranty claim after one of their mechanics (usually a dealer) has looked at the vehicle.
    This now puts you in the position of having to prove LR wrong and you need experts to do this.
    If you haven’t already I’d be asking LR to state that the cause of your problems is the suspension lift. Then I’d take it to ARB and ask them to fix the current and long term problem.
    If/when ARB refuse and you were in NSW I’d then go the consumer affairs tribunal it cost me some years ago $50. No lawyers but you do need an engineer (RAA?) to support your case.
    And let the Tribunial decide if ARB fix it or LR. If ARB were smart they may even support you. Certainly LR’s noted problems with the seal will go against them.
    Note in our case some years ago we were arguing that an engine rebuild hadn’t been done. Before the case could go to the tribunal we were forced to have the engine stripped down $1,000 engage an engineer for a report and tribunal appearance $1,500.
    We won the case. But time, money & experts. “Your” opinion on the cause will not count unless you’re an engineer/mechanic
    Adelaide Hills - SA
    How much is it to fix the rear seal (i.e. if you had to buy the part and get it fitted)?
    Might be quicker and cheaper then going the tribunal/legal route. Mrs Spud works for a Lawyer and she sees people's money removed from their wallets at prodigious rates for things that never should have got that far.
    Not saying it's right, but it might be the least painful way to go.
    Who are you dealing with at Solitaire? I have had good 'results' with Kevin (who seems to work for Jaguar) but he has organised a few things for me on my Range Rover that they were 'wavering' on.
    HTH
    David
