Results 1 to 10 of 14
Thread: Alloy cleaning have a look at my pics
    It'sNotWorthComplaining! Guest
    Doing a head replacement on Mums car( not Landy) but thought I'd share some pics of an easy clean.
    Sorry I didn't take the before pics of the oil stain gum on the inside, but if you have a look at the 1st of the pics there are a couple of black stains left.
    It took about an hour. I later did the valve springs, hydrauilc lifters. Everything was covered in brown gum
    the wonder drug was. 50% Chemtech 14 degreaser and 50 % Turps in a spray bottle. sprayed on let it sit for a couple of mins then used an old tooth brush and gave it a quick brushing, the stuff just started falling off, and not being corrosive like some degreasers it works a treat on alloy.
    I was pretty impressed so thought I'd show it here. when it was finished I then soaked it quickly in a 1 part to 100 parts water and hosed off.
    thats a lot of effort for what can be acomplished in a dishwasher with just a few button presses....
    Jul 2010
    Yep I'm with Blknight.....I've restored a few old motorbikes and the dishwasher will degrease steel and alloy bits a treat. The trick is to run a 'heavy' wash so the rinse cycle is longer than normal for the alloy bits.
    Once done, I run the dishwasher empty with 1 of the cleaning packs and it's right as rain - and just as clean with no smell or residual grunge!
    Adelaide - Torrens Park
    I can just imagine what my dishwasher would say if I told her to degrease a cylinder head!
    Moruya Heads/Sth. Coast, NSW
    Quote Originally Posted by BigJon View Post
    Mine would de-sex me, dangerous things these dishwashers, Regards Frank.
    Probably the same as mine.. Its a lot of fun pushing the buttons tho.
    But you have to have a bloody big dishwasher if you wanted to degrease an engine whilst it's insitu
    d@rk51d3 Guest
    Quote Originally Posted by It'sNotWorthComplaining! View Post
    You callin my missus fat?
    Dishwasher powder corrodes aluminium.
    Ipswich Qld
    Quote Originally Posted by Tank View Post
    and she would probably use a rat tail file mate
