Thread: Alternator HELP, two in one week!!
    Oct 2008
    Moved to Mallee/ Wimmera area in 2010
    Exclamation Alternator HELP, two in one week!!
    After seeing lots of use and mud etc I tought my alternator had died.
    My dash light didnt say it was faulty, it was just flattening brand new battery which cause the engine to flood and the Taco wont work at all below 2000rpm then it seems fine
    Car 92 3.5ltr disco
    Brand New spark plugs
    Brand New alternator
    Brand New alt belt
    Now it has done two hundred kms hwy and light off road and blown the brand new alternator again the same way, taco etc.
    Why am I blowing alternators???? It getting too expensive to run at $300 per alternator a tank of fuel.
    Also we live in rural Vic and takes a couple days to get things so its not just an easy trip to a landrover specialist. We do have a good auto elec but he is stumped.
    Oct 2008
    Sorry if you want to call me for questions or recommendations my phone number is 0416 051 450
    James
    Crafers West South Australia
    Take your dead alternator to a wrecking yard or auto elec, find a Bosch alternator that has similar mounting points. Could be something like Magna, XE-XF Falcon. Make this replacement alternator fit, you may need to fabricate brackets a bit. Then you will have an alternator that is easily fixed. You will need a connection soldered inside to one of the main diode-to-field connections, this wire is for your tacho to connect to. XE-XF has a small round pin on the back that is already connected this way. Should cost around $100.
    Oct 2008
    Thanks, I will talk tp auto elec about that, my main concern is why it has blown up two alternators and to stop it happening again.
    The battery was replaced a month or so ago is it possible it is causing the problem (if this has any effect)
    Don't really need a reason, things just happen sometimes. If you got to four alts I would start to worry. At least your Bosch won't need $300 to replace. Its main failure is the brushes and regulator and they undo with 2 screws from outside, cheep as. They are really easy to work on unlike most other branded stuff.
    Oct 2008
    I spoke to Auto elec he has ordered a replacement under warranty (reason for buying new). If I had of known the cost factor and the knowledge of the XF alternator I would have done that first. If second new one goes bang then I will ask for refund and chase the Bosch one.
    Thanks for your advise, I did think there would have been another fault causing it, auto elec said same thing as you "it happens".
    Quote Originally Posted by Stue 3 doors down View Post
    New Bosch regulator and brushes are $35. I bought a Bosch from a wrecker that had been reconditioned for $50 - works a treat.
