Page 1 of 7 123 ... LastLast
Results 1 to 10 of 70
Thread: P38 snorkel
    May 2008
    P38 snorkel
    The snorkel is finally on the Hard Rangie
    It has been a busy couple of days for Andy and I... just cleaning up now.
    Pics to follow later this evening, including:
    • front diff guard (one that is not a shovel)
    • HRA 3-hoop bar with work lamps
    Unfortunately, the sliders have slid (so to speak), but the rear bar/carrier should be ready by the LR Expo next weekend.
    Should also have the Warne 9000 winch fitted to the HRA bar then too.
    Here are the pics promised earlier.
    cutting the hole on the test guard
    First fitting
    Fitted with my guard
    Pic from tonight after re-fitting the 3-hoop Roo Bar and adding 2x 18W LED work lamps
    Not so happy with the Safari head, which sticks about 60mm above the roof line. Will look at other options, including making our own and/or having it integral to the mould.
    Also, need to finalise the fitting between the guard and the air box to get a good seal.
    A few imperfections/lines in the mould that will get smoothed out in the the next version.
    Also looking at a shadow indent for branding along the horizontal run.
    Not a bad effort for the first one.
    ...and it fits under my garage door (on highway mode) by a whisper
    Paul.
    Mar 2009
    Melton West, Victoria
    Looking forward to some photos !
    Feb 2010
    Townsville, QLD
    I'm looking forward too!! I had no luck with my snorkel... Not enough time to pull everything apart properly and get right in there for a look!
    Feb 2010
    Paul:
    Looking forward to snorkel pics.. also after an email back RE: Faultmate Pricing.
    Nov 2006
    narellan, sydney
    ahhh i have a bald patch. and i think i can see some greys. (pic 1. i have never seen a photo of the of my head before)
    Andy
    Quote Originally Posted by andrew e View Post
    Andy
    I've had the dubious pleasure of looking at it!
    NSW Far South Coast
    Looking good Paul/Andrew.
    Any place on the snorkel mountings for adding a CB aerial?
    Trev
    May 2008
    Quote Originally Posted by ytt105 View Post
    Trev
    possibly one of those aerial mounts that sticks out the side of the bonnet could be attached to one of the bolts on the guard... see pic below
    Next mould will have thicker/wider tabs to improve strength, although these are surprisingly strong and rigid as is.
    Cheers, Paul.
    Feb 2010
    Paul:
    How does the Snorkel affect visibility from a Driving Perspective.
    Because of it's location is it effectively "Hidden" completely by the Pillar?
    Looks fantastic, definitely eager
    WasabiPimpNinja Guest
    Looks good Paul, good work both of you Looks like I'm going to have to convince the Mrs that this is a necessity, not a want..
    I'm guessing by looking at the pics that this hooks up to the bottom of the airbox where the current water sucker is attached? Are there any airbox mods that need to be done? Also, what is it actually made out of?
    Keels.
