Graz, If you are working it hard, and there are NO external leaks, I would have to say it is a classic early Td5 head gasket leak.
A good test is to start from cold, drive up a reasonably steep hill, feed it into it a bit, (Not thrashing, just push it a little) and stop at the top. Check the cooling system for pressure, and especially see if there is a little bit of coolant in the end of the overflow tube...
There should be minmal pressure, as the engine shouldn't yet be a operating temp. If the top hose feels hard, and unusually hig in pressure, then it isn't a good sign.
JC
