Page 1 of 5 123 ... LastLast
Results 1 to 10 of 49
Thread: dual battery
    Jan 2010
    Australia, VIC
    dual battery
    Hey everyone, ive been looking at some dual battery setups, and came across this one which i can get for $165
    BAINTECH Dual Battery Control Kit | Dual Battery Isolators | Product Range | Bainbridge Technologies
    Has anyone used this one before? i only want to run a waeco fridge and a couple of camp lights off of the second battery, does this system 'check all the boxes'?
    and whilst im on the subject, where have you guys fitted your second batteries? ive seen the arb battery tray that mounts to the firewall, but i was wondering if anyone has removed their jack mounting, and placed the second battery next to the main one?
    thanks in advance!
    Jun 2008
    Quote Originally Posted by Pauly85 View Post
    thanks in advance!
    ARB one works ok but can only fit a 55AH max and the TD5's can cause some heat issues
    some people mount them in the rear storage bins (need to use a sealed batt) if you dont have the 7 seat version
    can run two batts where the original one was but you will need two new batteries (optima or exide orbital) as there isnt alot of room and the stock batt is pretty big
    Feb 2010
    KINROSS WA
    The position of the second battery will depend on your model and engine as the Diesel location is different to the V8. There are many threads on the subject of second battery box locations within the site just use the search function.
    Peter.
    Jan 2010
    Australia, VIC
    ok thanks heaps guys, i tried the search but didnt look hard enough, ill try again!!
    by the way its a 7 seater V8!
    Thanks again
    May 2010
    melbourne
    Has anyone relocated the air box to the rear of the engine bay? I've been thinking it may be an option.
    Make a custom snorkel and route the duct like a mantec.
    Jun 2008
    McMinns Lagoon NT
    Thanks again
    You can lock the search down to the D2 section although you may want to see installations in other vehicles.
    Make sure you include 'duel' as a search due to spelling errrors.
    You can check The Verandah for options from Traxide too. I have bought the latest unit.
    Cheers, Dale
    'The D3' - 2006 TDV6 HSE
    Previously Enjoyed:
    2000 D2 Td5 - plus!
    May 2003
    On The Road
    Thanks again
    using the advanced search,
    using "dual batteries:" as keyword
    searching entire posts
    in the D2 forum
    returns 33 results,,
    how many deal with 7 seater V8's is a mystery!
    Jun 2008
    McMinns Lagoon NT
    in the D2 forum
    And using 'duel' instead of 'dual'?
    Cheers, Dale
    Previously Enjoyed:
    2000 D2 Td5 - plus!
    Jan 2010
    Australia, VIC
    thanks guys! i re-tried searching and what do you know? it works if you spell things correctly haha
    will check the verandah now for the traxide unit
    in response to the arb unit which can only fit 55 ah max, how many hours would i get out of this running a 35 ltr waeco fridge/freezer?
    sorry for the stupid questions, im a panel beater.....i generally hate auto electrics!
    May 2003
    On The Road
    Quote Originally Posted by Stuuu View Post
    you end up with this--
