Thread: Fire Extinguisher location
    mattg Guest
    HI Guys.
    I am fitting one this week, where did you fit yours?
    I was thinking Passenger footwell or on the Tail Gate.
    what do you think?
    Matt
    Jul 2010
    If you have a cargo barrier - they hang off those pretty well!
    Crafers West South Australia
    Many threads on extinguisher location, e.g.:
    Good Place tp place a fire extinguisher? for Disco 2
    Searchy time.
    May 2002
    Heathcote (in "The Shire")
    Quote Originally Posted by Catmatt View Post
    Just make sure that they won't let go and scone you in a collision.
    Martyn
    Feb 2010
    Supine
    Useless in the rear if you have a cargo barrier. It needs to be accessible from the driver's seat. I have mine secured to the base of the front passenger seat. Does not impede the passenger, nor the action of the seat moving forward or rearward, and can be reached easily.
    Australia
    I am with Mick S. I wouldnt have it mounted in the rear. (a second in the rear is good)
    http://www.aulro.com/afvb/attachment...r-dscf0036.jpg
    cheers.
    Another thread from a little way back also to check out http://www.aulro.com/afvb/discovery-...inguisher.html
    Nov 2007
    Just remember to grab it every now and then and give it a good shake.... unless you are a regular on corrugated roads
    The last thing you want is to grab the extinguisher only to find out the contents have gone solid/settled effecting its efficiency....
    Personally I reckon those with the flexible hose would be best as you can keep the extinguisher upright and direct the spray to where its needed. eg. up and under a motor so you don't have to raise the bonnet or around the exhaust where grass has caught.
    New :- D3 TDV6 2006 SE
    Bullbar, traxide dual battery
    General grabber ATs
    Mitch hitch
    Home made drawer and fridge system
    Foldable UHF antenna on roof rail
    Aug 2009
    Brisbane, Sunshine Coast, Gladstone, QLD
    I would say definetely 2 extinguishers if you have a barrier.
    I will have one int he front mounted on side of centre tunnel and one on the rear door next to the fold down kitchen bench.
    Bracken Ridge, Qld
    ellard doesn't have this problem with many of his vehicles.....
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    Bunbury, WA
    I have mine mounted to the rear of my cargo barrier, up high and away from cargo etc.
    I can see an argument for mounting it within reach of the driver in say my rally car where there is a higher risk of a crash where a crew member may be trapped, but for a normal road car this is not really an issue. If you have a big enough crash to need an extinguisher, in a standard car with no helments and lap-sash seatbelts, you are going to be stuffed anyway. I reason that a much more probable fire would be a general campsite cooking fire or an engine fire, both requiring exit from the driver's seat to access it.
    The footwells of a D2 are pretty cramped as they are. The last thing you need is a passenger to step on it or bump it and set if off in the passanger area, or it to come loose itself in a crash.
    My 2c
    Chris
