Results 1 to 10 of 18
Thread: HID lights
    Feb 2010
    melbourne
    HID lights
    Hi anyone out there upgraded their puma lights to hid yet?.
    How was/is it and was it reasonably straight forward?
    Justin
    I did, and it is.....
    H4 Kits usually have a plug that operates the input for the lighting relay in the kit, and they draw the power straight off the battery.
    I pulled them out again and replaced them with JWSpeaker LED Headlamps.....
    Warragul, Victoria
    Be careful, unless you have levelers and washers on the lights they will be unroadworthy.
    Feb 2009
    In Australia it is illegal to fit HID headlights unless you have automatic leveling and washers. If you fit them you need to be aware of the possible consequences in the event of a motor vehicle accident and to your insurance.
    Quote Originally Posted by KarlB View Post
    defenders do have adjustable headlights just not automatic...I would say keep them on the most downward setting. not saying this would make it legal though
    SW of Geelong
    I stand to be corrected, but I think it's only illegal to have HID on low beam without auto leveling and washers. High beam is ok.
    You can get combo globes such as in this kit >>> hid H4/L 12v/35w <<<
    Cheers, Murray
    '88 County Isuzu 4Bd1 Turbo Intercooled, '96 Defender 130 CC VNT
    '85 Isuzu 120 Trayback, '72 SIIA SWB Diesel Soft Top
    '56 SI Ute Cab
    Feb 2009
    Washers are a more important issue than leveling as dirty lens can cause the light to scatter significantly and be quite dazzling. The situation is compounded if the globes are simply replaced with HID inserts as these apparently have different light emission points for which the reflectors and the lens are not designed. I think the washers have to be high pressure.
    The simplest way to get significant light improvement is to install a Traxide wiring loom (or equivalent) and/or replace the standard globes with something like Phillips X-treme Power or Osram Night Breaker globes which put out about 80% more light.
    KarlB
    Feb 2009
    Quote Originally Posted by rijidij View Post
    Cheers, Murray
    I don't want to get too deep into this stuff but ADR 75, General Specification 6.1 states:
    6.1 The headlamp cleaner shall be designed and constructed to clean those parts of the light-emitting surface of the headlamp which distribute the passing beam and the driving beam so that at least the cleaning effect specified in paragraph 7 below is achieved.
    Seems pretty clear to me that it is illegal to have any HID headlight beam without washers.
    There is quite a good discussion of this stuff by a fellow called TERRA Operative on the Mobile Electronics Australia Forum at HID lights - Mobile Electronics Australia if people want more detail.
    KarlB
    Torres Straits
    Karl I thought you promised...
    but whatever,
    I wanna know more about these LED lamps from JW Speaker
    A bit flash for my ol bush hack but at least stinking legislation doesnt rule on LED lighting at the moment! Give us a review Draymond. I was blown away by the light from some recently aquired via AULRO LED worklamps - and thought to myself - these are as good if not better than poxy halogens. Are they good? Price?
    Steve
    JDNSW's Avatar
    Quote Originally Posted by roverrescue View Post
    but whatever,
    Steve
    Actually, it does not rule on HID lights either - it only talks about brightness, but the figure is one that covers all HID lights on the market, I believe. I have no idea whether it covers LED lights, although a bit of a search would probably find the numbers. Last time I thought about LED lights I looked at the price and lost interest before going any further, but I am sure they will come down - just don't know how far down they have come already.
