Thread: TD5 Double Cab Central Locking Question
    Sydney, NSW
    Question TD5 Double Cab Central Locking Question
    Guys,
    One of my rear doors has stopped locking / unlocking with the keyfob.
    The mechanism feels fine when I push the lock button down and pull it up again.
    When I run the central locking tests in the 10AS module (Faultmate MSV2) I can hear the servo in the door working and it sounds like the sound the other 3 doors make under the same test.
    Any ideas before I start to strip the door down?
    Thx
    Jon
    Regards,
    Jon
    Oct 2008
    does the central locking work when you unlock it from the drivers door?
    Sydney, NSW
    Good question! I dont know.
    I'll have a try when I get home tonight and let you know.
    If it does, does that narrow down the possible cause?
    Thx
    J
    Regards,
    Jon
    Sydney, NSW
    Quote Originally Posted by Benny_IIA View Post
    Hi there,
    Just been outside to test. sat inside, locked / unlocked the front door, rear door did not lock/unlock.
    I can also confirm the rear door does not lock/open when i turn the key in the front door.
    Sadly answer therefore is No.
    Regards,
    Jon
    Regards,
    Jon
    Oct 2008
    Quote Originally Posted by Yorkshire_Jon View Post
    Hi there,
    Regards,
    Jon
    Yes I would remove the door trim and have a look. not a very hard job but those plastic clip always break
    Jul 2011
    Yarrawonga, Vic
    I have the same problem on my Defender , Rear driver side door.
    Took the trim off & everything worked fine, so I suspect the mechanisim fouls with the trim, bent / adjusted/ lubed with graphite. Put trim back on & same problem. Use Graphite , not WD40 as WD40 etc attracts dust & worsens the problem.
    There are dints around the door handle where it looks like the prev owner has been thumping it to get it to work.
    Be sure & get yourself a set of spare door trim studs ($6.00 ebay) you will need them.
    Sydney, NSW
    Thanks. Dont suppose you have an ebay link to the correct set of trim studs do you? My search revealled nothing.
    Thx.
    Jon
    Regards,
    Jon
