Maybe try a small squirt of Aerostart, that might prove if mechanically all is OK and point the finger at fuel. The fuel system can be a pain in the arse to bleed sometimesYou could also check the obvious and make sure the pump fuel cut off is in the run position, sometimes the linkages wear badly stopping full travel
Cheers Simon
