Hi gagsa and welcome to the AULRO.
First off, you need to let us know which pins of the 12S plug are connected to the Anderson plug but also check to see if you have blown a fuse for what ever pin is connected.
 Power from White Plug to Anderson Plug
		We had an adaptor made to go from the White Plug to the Anderson Plug by Land Rover dealer for our 2011 D4, and I have tested it with a multi-meter but it seems to only have .35 volt at the positive. I was expecting it to be 12 volt, so it would charge the battery in the Camper Trailer while travelling.
This was tested with the motor both on and off, there was no change to the resulting power output.
Not sure if this is normal or not?
hi drivesafe . checked fuse green 30AMP blown. battery fed positive on anderson plug goes to 4/R red wire. negative black wire goes to 3/31 and another black wire from the negative side of anderson plug goes to the centre pin looks like No58 on car plug. I tested the socket on car with voltmeter before pluging the anderson plug in could I have blown the fuse this way cheers
Wiring sounds correct, although you shouldn't need the earth from the centre pin of the 12S plug - that's the earth for the ignition-feed circuit.
You're powering from the constant-live circuit. Is that what you want (ie power fed from the car battery regardless of the ignition on/off)?
Gordon
Thanks Gordon,
I have put a new fuse in and everything seems to be ok now, we are now getting 12 volt power at the plug. Regarding the constant supply of power, I have to remember to unplug when I stop driving I guess.
 Fossicker
						Fossicker
						Hi Guys,
I would suggest it is better to run a dedicated circuit for the Anderson plug direct from the battery than running through the S type plug.
I have run my anderson plug through a 100Amp redarc SBI12 solinoid. This device senses the batery voltage and will automatically turn off when voltage drops, saving me from getting a flat battery. and saves you the effort of remembering to disconnect. (Pain in the rear end when you forget, even worse if you have an auto and shouldn't jump them I am guessing.)
I would also be concerned about the voltage drop being experianced accross the run. I have ran a fridge in a van accross my setup (not sure of the exact wire size but it is bigger than that on the car) and found over an 8 meter run that I was dropping about 1 volt when running 20 amps through the wire. Haven't done any maths on this but just be aware is my message.
When running a dedicated line, where do you take it from the battery ? simple question but I have had all sorts of advice.
there is an empty threaded hole in the terminal connector whatever that does, but do I just use that to connect to ?
DD
A dedicated line is always a better solution, however it's more complicated and I don't think it's necessary for loads under 20A or so. I've used the switched (ignition -fed pin) option in the S plug over the last 6 years to power the fridge in the various caravans/campers I've had (up to a 175 ltr fridge), and in all that time I've never had an issue. Yes there is a voltage drop (around 1 to 1.5V at full load), but the system works well enough and is switched, so you don't have to worry about forgetting to disconnect it.
Gordon
 Master
						Master
						I have also modified the white socket where I have removed all the pins taped them up then installed my own pins. Two were connected to my auxiliary battery and a third just to help line up and give a better plug fit. I then plug my caravan into the socket which runs a 12 volt to 12 volt battery charger in my caravan to charge the caravan battery. The charger cuts out if the battery supplying it drops below a set figure so as not to flatten the battery. This gives me two batteries if required. So if I disconnect the caravan from the car I still have battery supply.
Cheers Tinman
 Fossicker
						Fossicker
						Yes, I would come off the terminal connector itself with 1 wire of at least 8 mm size and stright to a circuit breaker or alike and then to a solinoid. This way you are not interfear with any of the existing electrics. You can also jumper this feed for your electric brakes if needed from the battery side. 1 wire to the battery then does everything for you.
Be careful of any fusable links on the battery connector - if you blow these they could be expensive to replace and whatever you do dont accidently short it out as who knows what you will destroy.
