Results 1 to 3 of 3
Thread: after market / add-on reversing camera
    Apr 2012
    Hi All
    I'm looking at a 2012 d4 SE at the moment. It has an upgraded audio screen thing to the 7" touch screen, but does not have a reversing camera or GPS. I've search the forum, but been unable to find a answer - can I install a reversing camera myself to this screen? Is it a standard video RCA type connection, or does something special need to be done through the Can-bus?
    Thanks, Andrew
    ps; thanks Sneig. Through your knowledge and postings here, I went straight to MLR. If/when I buy, ask for a commission
    May 2011
    Orange Grove WA
    Qld Volunteer Wanted - MY12 D4 with HK audio but no nav or camera
    G'day,
    A couple of posts down you will see this one.
    Have a peek and if you are in QLD you can be the guinea pig.
    I believe if you don't have sat NAV, this may be the answer.
    Brett....
    Dec 2009
    SW WA
    I don't think there is enough known about the 2012 models for anyone to give you answer yet. I gather the screen has changed since the 2011 models. Mine is a SE 2011 with touch screen and GPS, there was no touch screen without GPS then.
    I have fitted an after market camera to mine ex ebay. It has to be a NTSC camera (not PAL) for it to work (2011) and needs to be activated in the CCF by someone with a Faultmate or maybe the dealer (don't know if they can/will)
    The feed is standard RCA in that it is 2 wires but the plug is not, I mocked mine up from a similar computer plug. There is a six pin plug in the back of the screen with inputs for the reverse cam, tv, and can't remember cam. I would think if the six pin connector is there you are on a winner?
