If you are wanting to have the radio on to pickup the sound, just turn on the radio itself although IIRC it will turn off after an hour or if the battery voltage drops too much.
 Member
						Member
						Ignition will not stay on for longer than 10 mins.... Can you overide this?
 Swaggie
						Swaggie
Here's what to do.
First of all, get a second battery. Then take a portable radio with you and plug it into an invertor, which is plugged into a portable12 volt socket, ran off the second battery.
Problem solved.
Cheers, Craig
 Wizard
						Subscriber
						Wizard
						SubscriberLol, its tragic, isn't it?! A 100 Ah battery won't get you through a game of footy!
I'm putting in my Traxide this weekend... Bit nervous about DIY auto electrics, but everyone assures me Tim's made it a piece of cake!
Now 2016 D4 HSE 'Leo' and Steve the Triumph Speed Twin
Then 2010 D4 3.0 HSE 'James'
Then 2010 RRS TDV8 'Roger' w traxide DBS, UHF, Cooper Zeons, Superchips remap
Then 2010 D4 TDV6 'Jumbo' w traxide DBS
First love 2002 D2 TD5 'Disco Stu'
 Wizard
						Subscriber
						Wizard
						SubscriberOn the subject though, is it possible to stay in 'accessories' mode to use a power outlet?
 Master
						Master
						No I tried that at one point (before even realising I could just turn the radio on without the acc being on) and the battery went flat after a short time.
http://www.aulro.com/afvb/d3-d4-rrs/...ce-please.html
Can the 10 minute limit be changed via a Faultmate or similar setting at all ?
 Member
						Member
						Thanks everyone.... Looks like I'll be fitting a Traxide isolator and a second battery next weekend.... I'll post some pics
 Wizard
						Subscriber
						Wizard
						SubscriberI'm about half way after 5 hrs, a bit of skin and many cups of tea to gather my thoughts. The instructions are definitely comprehensive, and the tips are not worth ignoring, especially the one re tying string to the power socket extension lead to get it through the firewall above the accelerator. A little loop in the end of the string makes it very easy to pick up inside the engine bay with a bit of wire. That was still a two cuppa job!
One question:
Do ppl cut a notch in the battery-compartment lid to accommodate the positive lead coming in from the auxiliary?
