Mine used to do this at times, I found if you remove the key, lock and unlock it a couple of times it would start. I also found it did it usualy after leaving the key in the ignition for extended periods without locking the car. I got into the habbit of always removeing the key and had no problems after that. I dont know if thats the fix or just another Puma quirk.
Allan
