Results 1 to 9 of 9
Thread: A light I need a light
    Cranbourne North
    Ok I fess up I`m a nong. I keep leaving the twenty four volt key in the switch and over night it will flatten the battery's. As I start the old ute with twenty four volts this is not only annoying it also means I`m not going anywhere till the battery`s are charged. So what I thinking was a light, ah but no ordinary light. I need a light that comes on when the key is turned on to power the twenty for volt system then turns of when the motor starts. Much like a ignition light. But the 24 volt on the ute is supplied by a generator so a normal ignition light wiring is not a option. So that is question to you all. How can it be done? The twenty four volt key is a battery isolator key, so is only a simple rotary off on switch.
    Cheers Hall
    Crafers West South Australia
    Oil pressure light.
    From the Switched + side of the isolator to side one of the light from the other side of the light to the oil pressure switch.
    I would use one of the 24v bezel mount blinky imitates a security system led as opposed to a normal incandescent light.
    If its got a door light switch wire a 24v piezo buzzer between the switched side of the iso switch and the door switch That will make a buzzer sound any time you open the drivers door when the iso is on or the engine is running.
    Cranbourne North
    Thank you all for that. Have a light ( nice bright can`t miss it one ),so I`ll have to get a oil pressure switch.
    Cheers Hall
    umm no,
    a nice bright light will draw too much power for the switch to handle and will destroy the switch.
    Cranbourne North
    It`s just a 24 volt in dash warning light.
    Cheers Hall
    fair enough, but more than about 5w worth will toast the oil pressure switch contacts.
    (we may just have different definitions of the word "bright")
    Feb 2012
    Parkdale, Melbourne
    At what point on the scale are sunglasses required?
    - Justin
    '95 Disco 300TDI - sold
    '86 County 110 Isuzu
    2006 Range Rover Vogue td6
    some are less bright than others
    Quote Originally Posted by Judo View Post
    Just past the chums that are not very bright.
