Results 1 to 9 of 9
Thread: swivel hub seal advice
    Jan 2010
    tom price the pilbra, west aust
    I need to do one on the passsenger side of my 95 disco. got the kit and one shot grease, just after hints ideas etc ffrom those that have been there before.
    thanks
    Jun 2012
    Townsville
    Put the wheel face down on the floor and when you take the swivel/hub out of the axle place that face down into the wheel. -makes life a lot easier when swapping the seal! Also get a long handled ratchet spanner as it makes undoing the axle bolts a lot quicker and they are tight all the way to the end of coming out.
    + wear some latex gloves and have a can of brake cleaner to hand, makes clean up far easier
    Jan 2008
    Pialba, Qld (near Hervey Bay)
    Question
    Tell me how you go, as I need to do this on drivers side of my 96 but it has oil, & I'm a first timer too.
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by fonfe View Post
    Thats how i did mine as well, i also unbolted the whole hub/swivel housing from the axle tube and left the half shaft in place.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Jul 2012
    Kalgoorlie
    kit?
    Whereabouts did you get the kit from? How much?
    I need to do the same on my 98' Disco
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by sparky_pete View Post
    Its just a seal and some one shot grease.
    1974 VW Kombi bus
    Jun 2012
    Townsville
    Not sure if its any good as I haven't personally fitted one........
    But britpart do a cv type boot that covers the swivel ball....the idea being that it keeps out dust and grime that would normally stick to the ball and tear the seal.
    Was around £30 when I saw it a few years ago, may be worth a go as your doing the seals anyway?
    Going to fit them to my classic next time I have to do my seals if I remember
    St Helena,Melbourne
    4.28 MB
    I've seen them but i think they would also keep the crap in like mud and moisture and promote rust .
    1974 VW Kombi bus
    Jun 2012
    Townsville
    If fitted correctly then should be the same as a conventional cv boot that doesnt let it in there in the first place though so keeping it in wouldn't be an issue.
    I shall give em a go and let everyone know the results after a few trips through the mud
