RAR
froma  while ago and the pics are before it was finished but you get the idea
Ideas to finish off snorkel
So I run 80mm Al tube down the DS door pillar, straight through the wingtop (welded to wingtop for security) pipe then straightens as it enters the guard) 90 degree silicone elbow then some massaged 80mm across the steering arm to another silicone 90 into the bottom of the air can.
Only issue on the passenger side is if you have a heaterbox in under the guard - will make routing pipework challenging.
S
