Page 1 of 7 123 ... LastLast
Results 1 to 10 of 62
Thread: camper trailer questions...
    Palmerston NT
    Lightbulb camper trailer questions...
    Hi folks just bought me a 2nd hand camper trailer - seems like an oldie but a goodie.
    It has an anderson plug near the tow hitch which seems to be for charging the batteries as you're going along? Just wondering what the easiest/best way is to hook this up to the D4? I read somewhere that the left white plug on the back is for charging caravans etc.. can I get a converter or something? Or does it need another cable run in the car for this?
    Also... the trailer did apparently have a 4wd hitch system but the last owner put a normal ball hitch on the trailer... and didn't keep the old (Treg?) one... I assume this is just a matter of getting the right hayman reece style treg for the mitchel bros hitch, and bolting on the reciever hitch on the trailer drawbar? I've never used this style of treg hitch before... any suggestions on brand or whatever welcome!
    The camper is an offroad "aussie swag" model.
    Last edited by TerryO; 29th April 2013 at 11:44 AM. Reason: This thread will be moved to the Caravan and Camper section when it is no longer being discussed here.
    Dec 2009
    Ranelagh, Tasmania
    There is 12v at the white plug, however the wiring to it is much too small to carry the current required to charge or otherwise power your camper trailer.
    What you really need to do is add a dual battery controller (usually under the bonnet) and the appropriately sized cabling to the rear of your car to charge your camper batteries.
    If you go to the traxide website Tim has some good diagrams of what is required or you can buy the whole kit from him.
    As for the hitch, you can buy a new Treg system and bolt that to your camper. It will come with both parts and connect to whatever receiver you wish to use in the Mitch Hitch. I use an adjustable receiver so I can get the trailer level as the Mitch Hitch is fairly high.
    The Treg system is a good strong and reliable (if it is genuine) system, however it can be a bit of a pain to align when hitching and the poly block is prone to wear. I use a McHitch which is easier to connect and I think a better system.
    Fuji white RRS L494 AB Gone
    2023 Ford Ranga
    Palmerston NT
    Quote Originally Posted by Geedublya View Post
    Thanks mate - so you don't have a 2nd battery in the car but just the dual system to look after the trailer batteries?
    The McHitch system looks great - I'll reckon I'll give it a go
    Dec 2009
    Ranelagh, Tasmania
    I do have a second battery which I use to power my engel and other accessories.
    A dual battery is not required if you just want to charge the camper batteries.
    I should have mentioned there are other off road hitches such as the vehicle components DO-35, the Oz Hitch, Alko hitch and Hyland hitch.
    What I like about the McHitch is that the only moving part is the uni joint which is sealed and greasable by grease nipples. All the others either pivot around the pin/ball which can wear or have bushes that wear.
    The McHitch is not as easy to align as the ball couplings or the Oz hitch but I think it is a better design and not very difficult to hook up.
    2023 Ford Ranga
    Nov 2011
    melbourne
    Cant recommend the Traxide system enough. The kit comes complete with cables cut to length, anderson plug out the rear of your car...only needing to get your own battery.
    Then you will have ample power available in your car for fridges are other bits and bobs that take your fancy..all on the second battery..so no fear of a flat starter battery.
    The hitch question will open up a can of worms..everyone has their favorite. I use a DO35. They are super easy to use and the car/trailer do not have to be spot on to connect, but they are pricey.
    Whatever you decide, most important thing is to get out and use your new camper...and upload some pics to make the rest of us jealous.
    Feb 2005
    another vote for DO35 that Vehical Components make......easy to line up and drop n
    i see they have changed the design a bit HITCHMASTER® drop on couplings
    Nov 2011
    melbourne
    I forgot to mention brake controllers. If your trailer has electric brakes fitted, you need a controller fitted to you vehicle by law.
    another good investment is to ditch that OEM hitch receiver (plough) and fit a Mitch Hitch. It will give you higher clearance when towing. Mine has the tow coupling at 540mm high....but it all depends on your trailer
    Dec 2009
    Ranelagh, Tasmania
    The way I understand it brakes are required on trailers over 750kg, up to 2 tonne these can be mechanical (over ride) or electric.
    Over 2 tonne there must be a breakaway system fitted and the brakes have to be electrical.
    I believe if you have over ride and electric brakes fitted under 2 tonne there is no requirement to use the electrical if the over ride is in use. I have both on my camper trailer and at the moment I'm using over ride only. I have a brake controller which I am delaying fitting as I will probably get a new vehicle in the next few months.
    2023 Ford Ranga
    NSW SW Slopes
    Quote Originally Posted by jimc View Post
    The D4's doesn't have the same plough capability as the D3's.
    Feb 2010
    Get the White pug removed and put a dedicated Anderson Plug in its place. I did . Why keep something you will never use in such a useful spot?
    Wiring to my new plug much improved plug is much heavier to cope with charging my trailer battery!
    Some useful 'Do it yourself" examples exist or your nice Auto Electrician.
