unable to locate any numbers/ ID plates to give me the numbers I crave!
note the tyre holder on bonnett? should be on back of "seat wall"(ok front of tub)
spare diff on tray?
spare bumper too?
as you can see it has had a tree branch fall on it but no apparent damage
					 THE DAMAGE, NOTICE THE CHASSIS "FISHPLATE" TO BUMPER
 THE DAMAGE, NOTICE THE CHASSIS "FISHPLATE" TO BUMPER THEY KILLED IT !!
 THEY KILLED IT !!
 THE SCENE OF THE CRIME
THE SCENE OF THE CRIME THE PLATE
 THE PLATE THE BACK
 THE BACK , I'm trying to convince them a non syncro s1 swapped with a s3 109 6 cyl 109 wagon (with roof spinner) would be a good swap..
, I'm trying to convince them a non syncro s1 swapped with a s3 109 6 cyl 109 wagon (with roof spinner) would be a good swap..  As said though they are good people.
   As said though they are good people. THE FRONT - NOTE PIPE WINDSCREEN FRAME, NOTE SIDE FIREWALL LIGHTS, 50/51 GRILLE
THE FRONT - NOTE PIPE WINDSCREEN FRAME, NOTE SIDE FIREWALL LIGHTS, 50/51 GRILLE GRILLE/BUMPER (NOTE LATER CHASSIS CONNECTION)
 GRILLE/BUMPER (NOTE LATER CHASSIS CONNECTION) THE BACK
 THE BACK THE INSIDE (STEERING WHEEL? -NOTE INDICATOR AND HORN CENTRE)
 THE INSIDE (STEERING WHEEL? -NOTE INDICATOR AND HORN CENTRE) THE PROBLEM
 THE PROBLEM THE PROBLEM
 THE PROBLEM
