Does it lower when access height is selected?
Hello together,
I just realised the driver site of my D3 (air suspension) does not raise. I get no error warning it just stays on road height.
I drove around the block and thought it was just a bit slow to level but so far it has not risen.
Any ideas?
Thanks a lot
Steve
 Swaggie
						Swaggie
actually now it does lower and raises on all 4 wheels again, very strange just drove to get lunch and drivers site still lower after you asked put on access height no change back to normal height and it started working again now onLLAMS red and all raised
now went back to normal height and only drivers site lowered rest is on LLAMS red height not sure what is going on
 Swaggie
						Swaggie
						I suggest that you leave Llams switched off for a while and see if normal and off-road heights have the vehicle level as using Llams as well only makes it harder to work out exactly what is and is not working. If 1 front sensor is not working then the suspension system will still attempt to level but in a much more crude fashion, often leaving the vehicle not particularly level. Was the left height sensor or its wires affected by the damaged liner?
Edit: From the WSM
- Height sensor faults (hardware faults) and reservoir valve block failure
- Retain full functionality with no 'refinements', e.g. cross-link valves inoperative, no compensation for uneven surfaces.
 Master
						Master
						I had what sounds like a similar problem and it was the sensor. Plugged a reader into it and read the voltage parameters of the sensors and my back left was suspect so changed it and all good.
connock
according to Bruce Davies it is a issue with LLAMS according to him the plugs Graham uses are smaller then the default LR plugs and hence not a proper connection is made. so far I have met 3 people at DP who had the same issue with their LLAMS.
Graham could you please clarify
