It is interesting to note when operating the 101s winch by my self on the farm moving fallen trees and logs off fences and roads I can use the 101s winch capstan design to my advantage.
I can have the winch cable payed most of the way out and have the engine idling with the winch enguaged and the main gearbox in first gear and be out of the vehicle at the log I want to move and hook the winch cable up, the chain I have around the log and it will not winch in until I pull the cable tight back to the vehicle and then it will start pulling the log towards the vehicle.
If doing thing this way you have to make sure you are back at the vehicle by the time you want to stop winching.
It only mention the above to point out the fact the 101s PTO winch is different.
The 101s winch will give the same amount of pull regardless of how much cable is used unlike normal winches.
The 101s winch drum is for storage of the cable only.
Standard cable length is 65 mtrs, but the it will hold up to 75 mtrs of cable with no problems.
The 101s winch doesn't have a great pull of 6000lbs, but it can be used with a 2 to 1 snatch block and in 4th gear and still have along reach and faster winching speeds than a normal pto winch twice its size.
The overload clutch is adjustable via a allen head screw and lock nut.
The adjustment screw is only moved 1/8 th of a turn at a time.
I have posted this because our UK friends seem to be giving out incorrect information about operation of a 101s winch.
