You could pull the park brake emergency release cable to stop it engaging then don't use it until all sorted.  However because the cable re-connects the next time the switch is used, the misbehaviour may cause the switch to effectively be used thereby reconnecting the cables.
If you can get the suspension up to normal height you could then remove the main suspension system fuse (20A) from the engine bay fuse box.  The passenger compartment suspension system fuse (5A) can be moved to stop the incessant suspension warning message.
If you can get the transfer case into high range, you could try removing the transfer case ecu.  However the gearbox may then go into limp mode with only have limited gears available.
				MY21.5 L405 D350 Vogue SE with 19s.  Produce LLAMS for LR/RR, Jeep GC/Dodge Ram
