Thread: Leaf hanger bushes- removal?
    Feb 2010
    lismore
    Just wondering if anyone on here has any idea how to get the bushes out of the chassis? 10 tonne press struggle pushing the bushes out of the leaf itself
    WA
    Use an oxy to burn out the rubber - removing the rubber and inner tube.
    Then use a hacksaw with the blade inverted to cut through the outer shell carefully. (I usually make 2 cuts then use a chisel to remove the strip of metal between the cuts)
    ...or...
    Someone VERY skilled with a gas axe can cut the outer shell out without damaging the chassis...
    Narre Warren South
    Hacksaw (as mentioned by Isuzurover) and/or make up an extractor, both shown in this thread Getting the Series 1 Ready for Cooma
    I'm not keen on burning out the rubber, used coarse hacksaw blade to cut through it instead.
    Best of luck.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Feb 2010
    lismore
    cheers guys, will dig out the hacksaw tomorrow and have a go
    numpty's Avatar
    numpty is offline TopicToaster Silver Subscriber
    Nundle
    I've used both methods described above and much prefer burning the rubber out as it is so much quicker.
    Numpty
    REMLR No 143
    bushes
    I found using an electric drill with a drill bit sligthtly smaller in diameter than the rubber thickness,drill through the rubber all round the bush then knock out the centre piece.Also two hacksaw blades together in the hacksaw will give you a wider slot and with a cold chisel close up the slot and the outer metal bush should come.
    Feb 2010
    lismore
    Yea just burnt the rubber and pushed it out with the inner tube, then used my little friend To cut them and then just punch them out took about 10 15 minutes a side
