Thread: Mystery Oil Engine Bay: Photo
    Aug 2012
    North Loburn, New Zealand
    My Defender 90 Puma leaked some oil the other and looking in the engine bay it looked like watery oil all on one side - see photo. I'll crawl underneath later to see if there is a leak (perhaps I didn't tighten the oil filter tight enough recently). Just surprised it is right at the top of the bay can see it all over the battery isolator:
    Geelong, VIC
    Look for something that's leaking onto a moving/rotating part like a belt/fan/pulley. That will fling it everywhere in the engine bay.
    Steve
    1985 County - Isuzu 4bd1 with HX30W turbo, LT95, 255/85-16 KM2's
    1988 120 with rust and potential
    1999 300tdi 130 single cab - "stock as bro"
    2003 D2a Td5 - the boss's daily drive
    n plus one Guest
    Quote Originally Posted by Tikka7mm08 View Post
    Looks like it might be the common vacuum pump issue in its early stages?
    Jul 2003
    The Vacuum Pump is a plausible cause. Here are some links to a few of discussions on the Vacuum Pump issue:
    New Pumas with improved rustproofing
    Puma Part Concern
    http://www.aulro.com/afvb/90-110-130...tml#post841201
    Mahn England
    Ex 300Tdi Disco:
    Aug 2012
    Yep a bit of oil around the wabco vacuum thing. I see some people suggesting it doesn't always need replacing - seems a bit strange as I know Landys are awesome but self-repair seems a bit much to hope for!
    n plus one Guest
    Replacement Transit pumps and gaskets are cheap as chips on Fleabay. I've got a spare buried in the back of the truck for remote area work.
    You may get away with just a gasket if the mating surface isn't warped (which I think is the main cause if failure?).
    Kingston, Tassie, OZ.
    It was the other way round when I replaced a transit one recently, was cheaper through LR than Ford. had great joy telling the owner he has a 'landrover' part in his engine compartment now....
    JC
    Aug 2012
    Ah righto be cheaper than the LR agent!
    Aug 2012
    So LR seems more expensive but found these and seem right part. Price is sharp: http://item.mobileweb.ebay.co.uk/viewitem'sbk=1&nav=SEARCH&itemId=271141783703
    Aug 2012
    $530 +gst from LR agent here. Ebay looking sensible!!
