Results 1 to 6 of 6
Thread: Recovery points on a Defender?
    Sydney, Northern Beaches
    Greetings,
    I'm interested to hear what options are available for recovery points on a Defender? The best I've seen is a Jate Ring made by Troutbeck Sales in Melbourne. Anybody using them?
    I also like the idea of a centre pull recovery hitch that just slides into the towbar for recovery. Seems a hell of allot easier than accessing a point on the chassis.
    in case you guys were wondering ... yes ... I'm guilty of recovering on the lashing eyes ops: ... and realise the danger so I would like to get that sorted before my next trip.
    Henry.
    Defender200Tdi Guest
    Hi Henry
    There was some discussion on this not so long ago. Have a read through this thread:
    http://www.aulro.com/modules.php?name=Foru...recovery+points
    I too have used the Troutbeck JATE rings in the past and they seem like a good solution to the problem. The only drawback seems to be the fact that when you are stuck in the sand or mud, you'll need to start digging to find your recovery points. Other than that, they work well.
    Paul [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img]
    Jun 2003
    Launceston, Tasmania
    Most of the people I go out with have a hook mounted in the reciever of the towbar for the rear, works a treat.
    For the front, I have seen a couple of configurations, but as to which is best is open to opinion. I've seen jate rings, loops, hooks and everything between.
    1994 Discovery TDi
    2004 Discovery 2 TD5
    2010 Discovery 4 TDV6
    hooks
    check my setup under gallery and andy and the defender.
    two hooks on chasis rails
    Redbak Guest
    Had these fitted to the Fender, nice and cheap and strong
    but bury themselves in the mud, also the spring retainers
    rust and are pretty much useless after awhile.
    Davo
    May 2003
    On The Road
    nice photo though Redbak [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img]
    yea the thread above dissects this topic to death, with no apparent winner,
    again its a case of whats safe,
    what works,
    and what you can afford :wink:
