Results 1 to 10 of 15
Thread: How EAS Works - write up
    May 2008
    In the process of writing up a page about how the EAS works with diagrams and descriptions of the components in the system, and a bit of a FAQ.
    Input an FAQ questions welcome.
    How EAS Works | PaulP38A.com
    Cheers, Paul.
    Feb 2010
    Townsville, QLD
    Perhaps a link to the lift write-up in the FAQ section at the end would be the go ;-)
    Aug 2012
    Camden
    Nice work Paul. We might have another sticky right next to Keiths recent one
    My little input:
    Perhaps some diagnostics section might be good eg;
    If the car is on the bump stops in the morning step one is to unplug the EAS delay timer to see if its a leak or possible sensor problem etc.
    Coogee, South of Fremantle, WA
    Paul, can you add the best location to t into the air supply for a pressure gauge, tyre inflation and or locker use.
    I recall looking at the diagram in the P38A manual and deciding it was incorrect but I can't remember what was wrong with it.
    Douglas Park, NSW
    After carrying out an engine bay & fascia harness rewire this week, I'm surprised at the errors in the manuals.
    May 2008
    The diagram in the manual for connector C139 is wrong.
    Position 14 according to the diagram should go to pin 1, 15 to pin 2 etc.
    I have made aa note of this but need to test each pin to ensure it is correct at some stage.
    May 2008
    Quote Originally Posted by Keithy P38 View Post
    Give me the right FAQ question and I will do it
    Quote Originally Posted by Pete38 View Post
    My little input:
    Done, now included in the FAQ. Also added a Diagnostic section where I will review available diagnostic tools.
    Quote Originally Posted by wayneg View Post
    Feb 2010
    Townsville, QLD
    I don't have FAQ's for you Paul! Perhaps when my valve block decides it's had enough I might though!
    Aug 2012
    Camden
    Perhaps there could be a section that says that changing of height sensor arm lengths when applying a lift kit (insert your write up plug link here keith) could require changing the EAS settings.
