Results 1 to 10 of 13
Thread: Need to change pads and rotors, any suggestions? D3 V6petrol
    May 2008
    Hi folks,
    I think I need to replace pads and rotors as I feel the brakes pulsating when engaged. Any recommendations? I want low dust!
    GSL rally sport says I should go remsa pads and fremax rotors. Are they any good?
    Cheers!
    mandurah
    I have not heard of the brands you mentioned. There are other posts on the subject.
    PBR and DBA make std rotors for the D3. Look for Akebono ceramics, if you want a dust free pad. The brake wear sensors get quite brittle, and will generally have to be replaced. ( they break as you try to remove them ) You will need one front and one rear from memory.
    I am sure I posted numbers for these components. Do a search ( Akebono is probably the best option to search for ) and it will come up.
    D4 2.7litre
    Nov 2010
    Adelaide
    Thumbs up Akebono pads
    Last time I had my pads changed - went to Akebono. Brilliant! Not a bit of dust. Highly recommended!!
    Williams West Aust
    I know a lot of people say they are crap,I would look at slotted/drilled rotors.
    I have done this recently on my D2,went with OEM pads(As recomended and suplied by Justin Cooper).
    Much improved braking,not that the standards were duds.A mate also went the same way on his D2 after I did mine,he is a city driver where Im a country driver.He loves the improvement in his brakes especially dealing with the tossers on Perths freeways,its a must experience thing!!!!.
    I will go this way in the future with ANY vehicle I own that needs new rotors.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    May 2008
    Have decided on akebono, but couldn't find where to source them? Or should I just go to Pedders?
    Williams West Aust
    If Im correct,Admaril is a Pedders dealer,or works for one.He may be able to help you out.
    Andrew
    Bangor, NSW
    Quote Originally Posted by sheckster View Post
    Repco can also supply them.
    Mar 2007
    South Arm, Tasmania
    Depending on which LR dealer you are using (if that's where you get yours serviced) - they may be prepared to install the Akebono's for you.
    I had mine serviced where I bought it in Perth last week. They told me that I would probably be up for a new set of pads next service.
    I asked them about fitting Akebono's. They stated that they had never heard of them (looked them up on the intergoogle while I was there and seemed impressed). They said that if I supplied them, they would be happy to install and would be keen to monitor them and see how they compared against what they fit as standard for wear / performance / dust generation etc. Gotta be happy with that.
    Part Numbers from Pedders are PEUR1098 (front) and PEUR1099 (rear). Pedders do not supply the wear sensors - use genuine Land Rover ones.
    Cheers .........
    BMKAL
    May 2008
    Just got a quote from Pedders. Pads, sensors and mahonia for all 4 corners total is $974. Wow, these things are a bit expensive!
    May 2008
    Opps, meant to say 'machining'
