Page 1 of 6 123 ... LastLast
Results 1 to 10 of 52
Thread: knocking sound front suspension
    Sep 2012
    Maroubra, NSW
    Ended up with a knocking sound coming from the right front suspension (D4) toward the end of the D3/D4/RRS 4WD Weekend in Lithgow on Sunday. No issues when back on the tarmac on the run home but knocks again when driving over small bumps/potholes.I’ve jacked it up but there’s no visible damage to the suspension/ball joints/control arm etc – any ideas?
    BTW – Thank you TerryO and George for a great day around Lake Lyell
    May 2002
    Heathcote (in "The Shire")
    Never looked under a D3/4, but loose shock absorber (worn rubber) ?
    Martyn
    May 2010
    melbourne
    My RRS just developed a knocking sound over small bumps and just after a weekend of 4wding, found to be the sway bar bushes. Was told they weren't too bad and could wait till the next service, but as I found it annoying, had them replace anyway. A few hundred to fix, much cheaper than lower arms, so better result than expected.
    Sep 2012
    Maroubra, NSW
    Thanks Bushie. The D4's got air suspension which is operating correctly and there's no visible damage there either. I suspect it may be a steering arm but will leave that up to the experts on this forum Hopefully not too expensive to repair please!!
    Jan 2012
    Quote Originally Posted by LiamO View Post
    Ended up with a knocking sound coming from the right front suspension (D4) toward the end of the D3/D4/RRS 4WD Weekend in Lithgow on Sunday. No issues when back on the tarmac on the run home but knocks again when driving over small bumps/potholes. I’ve jacked it up but there’s no visible damage to the suspension/ball joints/control arm etc – any ideas? BTW – Thank you TerryO and George for a great day around Lake Lyell
    This is really creepy - I've got exactly the same problem after that weekend! Mine has around 40k Kms on her at the moment and a noise from front right also!!! Let me know what you come back with - I have to wait a while then send it in for a pre end of warranty check up!!
    Dec 2009
    Ranelagh, Tasmania
    Lower control arm bushes are probably the most likely suspect. I'm just about to order new arms from the UK to fix mine.
    Fuji white RRS L494 AB Gone
    2023 Ford Ranga
    Quote Originally Posted by Geedublya View Post
    Sounds like it to me too, same thing happened to me about 18 months ago after an offroad weekend.
    Ellendale Tasmania.
    While you are having the lower control arms looked at, either by you or your mechanic, check the connects from the sway bar, the top and bottom nuts can come loose(so I found out) I had this exact issue, after I had my lower control arm bushes replaced, we went out driving and when the weekend was over, I notice a slight clunk, which got worse over time, top nut on the sway bar connect was loose, tightened it up, no clunk.
    Baz.
    Cheers Baz.
    2011 Discovery 4 SE 2.7L
    2007 BMW R1200GS
    1979 BMW R80/7
    1994 Yamaha XT225 Serow
    Yass NSW
    Clunks from the front roughly in the order I have sorted them:
    Lower control arm bushes worn
    Rack ends or tierods worn ( easy to check for steering play )
    Rubber mounting bushes for sway bar
    Links for sway bar
    Clunks from the back:
    Sway bar mounting rubbers
    Sway bar links
    Rear castor rod ends
    Maybe bushes but mine seem OK so far.
    Regards,
    Tote
    AndyG's Avatar
    AndyG is offline YarnMaster Silver Subscriber
    Jan 2014
    PNG
    Knock knock
    Who's there
    Cyclist from Lithgow
    apologies to Socrates
    Clancy MY15 110 Defender
