Results 1 to 10 of 21
Thread: Heavy duty drive flange
    Aug 2009
    werri beach NSW
    I recently purchased 2 new Terrafirma drive flanges at the LR expo and I am about to fit them but I am not sure about the o ring seal. I have fitted the nut onto the flange and tightened it onto the o ring but it just squeezes out. Do you tighten it up the nut or tighten it just enough to compress the 0 ring a bit and use a bit of locktight on the nut to hold it.
    Thanks for any help with this.
    Safety Bay
    Just enough to compress it with thread locker. Pat
    Safety Bay
    Forgot to add,put a blob of grease in the cap to lube the splines. Pat
    Apr 2013
    Cairns
    I threw the o ring away, added sealant to flange face, then put nut on tight. Been working fine for over 2 years. They still come off, just put on new goop each time.
    Mar 2007
    Canada
    Sounds like a bad design. There should be a place machined in the cap for the o-ring to be held so that the cap can be fully tightened.
    Aug 2009
    werri beach NSW
    I think its a bad design also not that well thought out. What are the other brands like.
    Mar 2007
    Canada
    The only others I've looked at are Ashcroft and Maxidrive, both which seal properly.
    Aug 2014
    I've fitted these and yeah they are poorly designed I did the same as micksta and just use sealant and ditched the oring
    May 2012
    Boulder, CO
    Quote Originally Posted by skoller View Post
    Just put Ashcroft's on mine. Very nice! There is a spot for the o-ring; they seal nicely.
    Aug 2009
    werri beach NSW
    If I was still working I could get the machinists to machine a groove in the flange to accept an o ring and all would probably be ok. Should have went with quality gear.
