Results 1 to 10 of 16
Thread: Gas leak detector
    South East Tasmania
    Gas leak detector
    I am after a detector for occasional use in my RRC.
    I appears to me that is a leak on the diaphragm but without a tester is hard to say.
    I do not want to use a match
    Can any of you recommend one tester that is reasonable priced?
    Arthur
    Oct 2012
    FNQ
    Arthur
    Detergent and water mix brush on and look for bubbles
    Jaycar sells one for about $40 but the air needs to be perfectly still.
    South East Tasmania
    So in both options it cannot be tested with the engine running.
    With the ignition on (without crank the engine) should be gas on all the lines?
    The engine is a V8 3.9 fuel injected.
    Oct 2012
    FNQ
    Soapy water will work with the engine running ,fairly dear tho
    Wheelers Hill, Melbourne
    Occasional use??
    Crafers West South Australia
    Quote Originally Posted by DeeJay View Post
    Occasional use??
    Noses are good for finding the general area of a leak, soapy water lets you home in on the exact spot. Note that a bit of caution is needed, some leaks are big enough to blow the soapy water right away from the leak making it important that you observe the area very carefully as you apply the liquid. The only real advantage of a gas leak detector over a properly calibrated nose is the length variable...
    May 2009
    Tatura, Vic
    Is this a duel fuel? If so and being injected they are usually set up that they start on petrol and then switch to gas.
    This being the case, there would be no gas present with out engine running.
    Dave.
    I was asked " Is it ignorance or apathy?" I replied "I don't know and I don't care."
    1983 RR gone (wish I kept it)
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    South East Tasmania
    Quote Originally Posted by d2dave View Post
    I used to have a 1978 109 Stage 1 running on dual fuel and yes I start it on petrol and then switched to gas but not in this one.
    Do you mean for a usually set up as something automatic or just the common norm?
    The change over is manual like on the 3.5 carby 109 and so far I never run it on petrol.
    Some people believe that should run on petrol offten because the valves seats other said that the 3.9 have strong valve seats.
    I was considering to install a valve saver on it.
    I have this RR for only 3 weeks.
    For a RRC Classic era vehicle, I'm pretty sure the solenoid will only open when you crank the engine over. There may be gas pressure in the line left over from last run though. Some of the earlier safety devices had a relay that powered the gas valves ( solenoids) from when you cranked it, not just turning on the ignition. Using my '85 County as the experience.
